water pump
Old Jan 8, 2003 | 01:15 PM
jakfrost84's Avatar
Default water pump
My water pump went bad, i plan on replacing it soon. Is there any advice or tips on putting a new one in? im replacing it on my d16z6.
Old Jan 8, 2003 | 01:24 PM
Crazydave's Avatar
Default Re: water pump (jakfrost84)
replace the timing belt... and your other accessory belts..
as well as your valve cover gasket.. do your thermostat too
inspect your motor mounts too
to take the crank pulley off you will need an air gun or the special tool
if you haven't had head work done..
but you are thinking about it..
might as well do it now too..
95_eGsix
Apr 14, 2010 06:44 AM
JasonYo
Mar 22, 2010 08:52 AM
Mr_Moos
Jun 24, 2007 10:04 PM
Project_ED8
Mar 22, 2004 01:37 PM
pnthr30
Oct 31, 2003 07:29 AM
