Question for ecu chipping experts
Old Jan 8, 2003 | 11:55 AM
Wes d's Avatar
Default Question for ecu chipping experts
A friend of mine gave me this p28 ecu along with a swap. So I popped it open only to find that the parts were not soldered in only placed in there. So I assumed these are the correct parts and pieces and finished soldering it in. Then installed it in my car, and not to my surprise the CEL stays on and the engine barely runs. I have never seen a chipped ecu so I have no idea if these parts I soldered in are even supposed to be in there. Does this setup look right to anyone??
[Modified by Wes d, 9:00 PM 1/8/2003]
Old Jan 8, 2003 | 12:07 PM
Skunk2_92gsr's Avatar
Default Re: Question for ecu chipping experts (Wes d)
I have no clue but personaly, i would have asked him first. Badly chipped ECU's can seriously **** up a engine. I read a story somewhere about a guy who got a baddly chipped ecu and it advanced his timing 40 degrees
Id ask him about it. If he has no answer... I dont know what to do.
Old Jan 8, 2003 | 12:42 PM
Shawn C's Avatar
In The Garage
Default Re: Question for ecu chipping experts (Skunk2_92gsr)
IM kenji. hes the honda chipping expert on here.
Old Jan 8, 2003 | 02:22 PM
eg6ajk's Avatar
you the right components. the problem could lie in few ares. such as:
1) wrong chip for the ecu (EPROM)
2) burnt/blank chip
3) improperly soldered on parts (ie. check pin #1 on the hc373)
4) possibly a short on the otherside of the PCB
I persoanlly would suggest looking at both side of the board (PCB) to check all the leads for any shorts first. check that the parts are soldered on both side and that there is no open pins. check the socket and make sure the chip is in all the way.
also please slap a sticker on the chip before it goes blank. EPROMs with windows are UV erasable. so camera flash, light can damage the data stored.
waynebennett
Jul 18, 2010 06:42 PM
sesk
Jan 11, 2003 03:13 PM
