Vtec stuttering
Old Sep 7, 2011 | 07:06 PM
jasonboyce03's Avatar
Default Vtec stuttering
for some reason my vtec sputters. its like its cutting on and off when it enes. it sounds like its hiting a rev limiter but keeps accelerating. the first time i hit vtec after i start and warm it up vtec works fine then i try to engage it again and it starts sputtering . any ideas. checked the wiring. cleaned the solenoid. oil level is good. i let the car warm up. i really dont know . please help i have a b16 head with a gsr black p28 ecu
Old Sep 7, 2011 | 07:18 PM
civickiller's Avatar
Default Re: Vtec stuttering
lean, p28 is a sohc v d series ecu not a b series
Old Sep 8, 2011 | 06:13 AM
how can i fix that. get it tuned?
Old Sep 8, 2011 | 10:52 AM
95 integra's Avatar
Yes, that should've been your first step. I hope you are atleast running some type of tune other than the stock civic one.
Old Sep 8, 2011 | 02:44 PM
mibayaua's Avatar
Off the subject, hey 95 Integra, I noticed that you had an Integra that was making that damn buzzing sound from the abs pump,,,,How did you fix that? or you didn't, I noticed that annoying sound after bleading the breaks and the ABS
Old Sep 12, 2011 | 09:57 AM
yeah im running crome and a chipped p28. im going to get it tuned within the next few weeks and ill let u know if that fixed it
Old Sep 12, 2011 | 12:04 PM
95 integra's Avatar
Been there before. I just happened to luck into one (after owning 10 or so) that doesnt buzz. As I recall (from about 8 years ago), when you bleed the abs it has a tendency to cause the big brown can to go bad....sadly, I believe it is a pita to replace (its under high pressure) and cost quite a bit of cash.
DC2MeCZoom
Engine Management and Tuning
Apr 4, 2012 07:52 PM
Mr.Kalinchuk
Aug 9, 2009 05:35 AM
battleREADYb20
Mar 22, 2008 11:33 PM
slowcrxsib16
Jul 9, 2006 08:49 PM
schtozo
11
Feb 14, 2004 04:31 PM
