Vtec problem...please look.
Old Feb 19, 2008 | 06:46 PM
91EF_Si's Avatar
Default Vtec problem...please look.
So I bought a 91 Civic with a 94 GSR swap. Vtec will only work if directly connected to a toggle switch and will bog in and out of vtec at around 6k +. Always done this since I've had it. Any ideas?
Things changed/checked.
Oil is fine.
Rewired vtec and other sensors.
Changed vtec selonoid.
Tried other virgin/chipped ecu's.
Running str8 pipe, so no cat.
And only CEL on throwing is 6 Engine coolant temp sensor, and thats because it's not plugged in.
Things that I think can cause the problem.
Preety bad dented oil pan.
Don't know the condition of either oil pump or oil pick up.
And maybe fuel, even tough fuel gauge reading 50 at idle.
Please help..
Old Feb 19, 2008 | 11:14 PM
89s1's Avatar
Default Re: Vtec problem...please look. (91EF_Si)
get rid of the CEL obviously...
and if your car still like crap after that try a friends dizzy
Old Feb 20, 2008 | 06:19 AM
91EF_Si's Avatar
Default Re: Vtec problem...please look. (89s1)
Oh forgot to mention. I already changed the dizzy too.
Old Feb 20, 2008 | 08:55 PM
91EF_Si's Avatar
Wired the sensor, so no more CEL. Also vtec works propely, so no more vtec problem. But it still has the problem....
help..
Old Feb 21, 2008 | 04:49 AM
B16B_coupe's Avatar
HRD PKR
So it still bogs in and out? Check your fuel pressure.
Old Feb 21, 2008 | 05:19 AM
91EF_Si's Avatar
Default Re: Vtec problem...please look. (B16B_coupe)
At idle fuel pressure is at about 45-50. and when i rev it up, its stays at the same spot.
Old Feb 21, 2008 | 09:25 AM
sanimalp's Avatar
$cat /dev/urandom
what about oil pressure.. i dont think fuel pressure is a factor in vtec engagement, when vtec is hooked up correctly. if your oil pressure is too low.. vtec wont engage or stay engaged.
Rob1242
Aug 14, 2009 04:47 PM
91EF_Si
Feb 23, 2008 07:53 AM
h22a1_julien
Aug 27, 2007 01:44 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
MontrealR
Sep 15, 2001 07:51 PM
