VTEC NO WURK!
Old Mar 20, 2005 | 08:14 PM
sacjdmz's Avatar
Default VTEC NO WURK!
I own a 1990 Integra and i recently put in a OBDO JDM B16A.
My problem is that my vtec doesn't work because of my speed sensor.
I've already tried new speed sensors but here's the thing, when I insert the speedometer cable's end into the speed sensor and install the retaining clip, I spin the bottom gear of the speed-sensor and the needle on the speedometer jumps naturally. But when I install into the transmission, it doesn't work??? I don't know what the problem can be because I don't really know the internals of a transmission. And when I drive, my car pops out of 5th gear? Do any of these things and problems add up? Or are they completely different?
All the replies are much appreciated
Old Mar 21, 2005 | 07:00 AM
H22A_NeThing's Avatar
Default Re: VTEC NO WURK! (sacjdmz)
As for the speed sensor i dunno, but the tranny popping out is either your shift linkage (make sure everything's nice and tight) or a tranny problem
Old Mar 21, 2005 | 08:07 AM
evilhatch2.0's Avatar
Default Re: VTEC NO WURK! (H22A_NeThing)
how do you know it's actually because of your speed sensor. what computer are you using?
Old Mar 21, 2005 | 06:39 PM
sacjdmz's Avatar
Default Re: VTEC NO WURK! (evilhatch2.0)
What does the ecu have to do with it?? Its a PWO (OBD-0 CRX B16A)
Old Mar 21, 2005 | 07:23 PM
what do you mean "what does it have to do with it?". then why are you asking about your speed sensor and your vtec not kicking in?
As far as your vtec- It still should kick in without your speed sensor working.
Old Mar 22, 2005 | 04:20 AM
JimBlake's Avatar
I don't know about 1990, but I'm pretty sure that for many years, the ECU won't trigger VTEC unless the VSS is showing at least some speed.
Old Mar 22, 2005 | 07:49 PM
sacjdmz's Avatar
so your saying that if I run a different ecu my speed sensor will work?
Old Mar 23, 2005 | 04:21 AM
jamey220's Avatar
speed sensor should not have anything to do with the vtec, i have a 90 accord with an h22 swap with no iab or speed sensor and my vtec still works, but i have my vtec on a push button on my gear shift, what kind of car do u have and did u have to wire the vtec up manualy?
Old Mar 23, 2005 | 09:43 AM
panix's Avatar
Default Re: VTEC NO WURK! (jamey220)
that is sick!!! How does one go about that ??
99Civic-EX
Jul 25, 2007 11:44 AM
686_ef
11
Apr 6, 2005 05:57 PM
sacjdmz
Mar 20, 2005 09:40 PM
miataguy
Jul 17, 2003 02:25 PM
