Wiring Harness question please help
I have a 92 cx hatch it had a z6 swap in it so it was already wired up for vtec and had a vtec harness in it. I am putting in my built ls-vtec with a p72 ecu. My engine harness got misplaced so now I need a new one. My question is can I use any 92-95 vtec harness without any problems and i also have a four plug 02 sensor. So what harness can I buy and not have to worry about wiring anything up besides the knock sensor ?? Any help is appreciate thanks
Re: Wiring Harness question please help (hatch b16a guy)
Use the harness that is in your car, and get plugs from any vtec engine (if you need the knock/vtec plugs) and any other plugs you may need you can find in any other civic/integra harness.
Replacing a huge bulk of a wiring harness is really stupid (unless the car started on fire or something....) because all that will do is make it that much more likely that if an electrical problem were to occur, now you have to trace EVERYTHING in the car.
There are lots of posts on here about swap wiring, its very simple, certainly does not require a harness transplant.
