VTEC Enagement Problem
Old Apr 8, 2004 | 03:30 PM
crippledeg's Avatar
Default VTEC Enagement Problem
I have a NA LS/VTEC
My problem is that VTEC engages then turns off. then it has hesitation in the top half of the power band. IE 5500-9000.
I unhooked my VAFC
I checked the solenoid and the screen
The pressure @ the solenoid
I checked a variety of ECU's
The dist. (the cap, rotor,etc)
The plugs, and wires
Everything works and the pressure is there
Below where ever VTEC is set at it, it pulls strong,
when it's suppose to crossover, (anywhere it's set) it goes in then out.... finally coming on with a big power loss and hesitation Like a stutter around 7500-8500
It ran fine then out of no where this BS happens
Nothing seems to work
Any help would be greatly appreciated
Old Apr 8, 2004 | 07:49 PM
Joel_MN's Avatar
Default Re: VTEC Enagement Problem (crippledeg)
OIL
Old Apr 8, 2004 | 09:04 PM
90dxhatch's Avatar
Default Re: VTEC Enagement Problem (Scribes)
yeah mine did just that, drain and refill.
joe
Old Apr 9, 2004 | 05:12 AM
RTE117's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scribes &raquo;</TD></TR><TR><TD CLASS="quote">OIL</TD></TR></TABLE>
Yep! I had this happen once, I was like WTF is going on. Changed my oil the next day for routine change and voila all better.
Old Apr 9, 2004 | 08:07 AM
94RedEGCoupe's Avatar
Default Re: VTEC Enagement Problem (IDriveAHonda)
I have a 94 Ex with a JDM B18C and I don't get any kick with my VTEC. You can somewhat hear it at 5500, but there is no pull to go with it. I have changed oil, taken the solenoid apart and cleaned screens... do anyone have any other ideas?
Old Apr 9, 2004 | 08:32 AM
RTE117's Avatar
Default Re: VTEC Enagement Problem (94RedEGCoupe)
5500? Wouldn't that be the RPM the butterflies open.. GSR crossover is 4400.
Old Apr 9, 2004 | 11:33 AM
If it's 4400 then something is way wrong. I ran 16.2 at just over 85 mph at the track. I could not feel or hear anything close to what I have in other dohc vtec cars. Do you have any ideas about what could be wrong?
Old Apr 9, 2004 | 12:03 PM
Ditdogs's Avatar
what trans are you useing? 16.2 for a b18c in a coupe is slowwwwwww.
even if vt2c was opening at all, you should be running 15's
Old Apr 9, 2004 | 12:15 PM
Default Re: VTEC Enagement Problem (Ditdogs)
I have a civic si trans
Old Apr 9, 2004 | 05:36 PM
Joel_MN's Avatar
i think vtec crosses at 4400rpm, factory set, and the secondary manifold butterflys open at 5700.
I have an apex-i N1 exhaust, and can definatly hear when vtec crossesover, feels like a slight gain in power, but when the secondarys open is where i feel the most pull.
Old Apr 9, 2004 | 06:14 PM
hondamanwill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scribes &raquo;</TD></TR><TR><TD CLASS="quote">i think vtec crosses at 4400rpm, factory set, and the secondary manifold butterflys open at 5700.
I have an apex-i N1 exhaust, and can definatly hear when vtec crossesover, feels like a slight gain in power, but when the secondarys open is where i feel the most pull.</TD></TR></TABLE>
this is correct
Old Apr 9, 2004 | 06:28 PM
Default Re: VTEC Enagement Problem (hondamanwill)
I have a type R header and Apexi World Sport exhaust and I got nothin...
Old Apr 9, 2004 | 08:13 PM
Ditdogs's Avatar
what ecu are you running, and do you have any vtec units? such as Vafc vtec controller?
Old Apr 10, 2004 | 07:09 AM
I run the JDM GSR ECU, I don't have a VTEC controller yet, but I think I'm gonna get one next week
Old Apr 10, 2004 | 08:30 AM
spaceman's Avatar
is there anything else that would cause vtec not to work?
Old Apr 10, 2004 | 11:02 AM
Ditdogs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94RedEGCoupe &raquo;</TD></TR><TR><TD CLASS="quote">I run the JDM GSR ECU, I don't have a VTEC controller yet, but I think I'm gonna get one next week</TD></TR></TABLE>
pull the ecu and look to see what # is on it to me 100% sure it is a gsr ecu. a few people have put a ecu in that wasnt vtec enabled and couldnt figure otu why vtec wouldnt open.
JSpekBB4
Oct 30, 2007 10:23 PM
h22a1_julien
Aug 27, 2007 01:44 PM
jagged4698
Apr 1, 2005 06:23 PM
crx_kid
Nov 15, 2004 04:47 PM
PhilStubbs
Apr 24, 2003 05:10 PM
