VTEC bolt sheared flush with head
Old Aug 23, 2014 | 10:00 AM
sixstroke's Avatar
Default VTEC bolt sheared flush with head
So, I'm one of the lucky few who has seemed to accomplish this great task!
I already purchased an extractor kit and I became even more lucky as the extractor snapped inside the bolt.
Does anyone have some tips or insight into my situation?
How much meat is around the top left VTEC solenoid bolt, can I drill it out much bigger and tap it?
Thank you
Old Aug 23, 2014 | 11:43 AM
sixstroke's Avatar
Default Re: VTEC bolt sheared flush with head
Hahah it gets better.
I drank two beers and attempted to remove myself from the situation for a while. Went back at it and drilled into some fresh metal, attempted to tap it and the tap broke...China is really ******* me over today.
I'm about to JBweld it on...
Old Aug 23, 2014 | 11:52 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you were screwed as soon as you bought the extractor, NEVER use those things, some machinist who was pissed at the world invented them as his revenge. the extractor is almost as hard as a tap, and once a tap breaks you are done. all they do is break and they are nearly impossible to remove, if someone brought me that part with a busted off extractor and tap, I would tell them get a new part
Old Aug 23, 2014 | 12:14 PM
bgdriver's Avatar
MIG weld a nut to it and unscrew. Weld won't stick to the aluminum.
Old Aug 23, 2014 | 12:34 PM
sixstroke's Avatar
Well, most of the bolt is out, however, I feel as though I've taken a lot of the metal around the hole with it.
I'm going to hope there is enough meat left to insert a helicoil or timecert.
Old Aug 23, 2014 | 12:56 PM
sixstroke's Avatar
Yep, the head cracked around the cuff of the bolt hole..
Old Aug 23, 2014 | 01:20 PM
F22Master's Avatar
Grind out all of the messed up.material, tig weld the are back up. Drill and tap a new hole, grind surounding excess weld flat.
Old Aug 23, 2014 | 01:27 PM
Old Aug 23, 2014 | 02:06 PM
sixstroke's Avatar
You're telling me...today was supposed to be an easy day.
Old Aug 23, 2014 | 05:54 PM
holmesnmanny's Avatar
That really sucks, man. Youre not alone. We've all had days like this.
Old Aug 23, 2014 | 08:20 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
We have, but it comes down to the right tools for the right job. From the pictures it was a botch job at best. Left-handed drill bits and some heat go a long way. Now me and the mad scientist are going to have to... oh wait, never mind, wrong part.
Old Aug 24, 2014 | 12:45 PM
sixstroke's Avatar
Does anyone have any experience with aluminum fillers? I've seen several that advertise that they can be tapped etc.
Thank you
Old Aug 24, 2014 | 12:47 PM
Thank you
I've never seen one that really worked or lasted very long
Old Aug 24, 2014 | 03:38 PM
F22Master's Avatar
You need to fill it with tig weld.
Old Aug 24, 2014 | 04:43 PM
sixstroke's Avatar
That would be awesome. But I don't have access to a TIG and the car isn't running currently.
JDM787
Apr 16, 2016 04:54 PM
Sugar Shane
22
Oct 17, 2012 07:59 PM
pmey
Feb 9, 2009 02:02 PM
Methane2k2
Dec 15, 2004 12:57 AM
shadowstylz
Sep 16, 2003 10:20 AM
