A very hard ECU question?
Old Jan 9, 2003 | 07:58 PM
mattcxb18's Avatar
Default A very hard ECU question?
I sounds crazy, but it is true. My car runs perfect all the time except for one thing.
When my ecu gets colder then about 50 degrees it will not allow my car to run. How can I fix this?
It sux whenever it is cold out i have to bring my ecu in the house or warm it up outside some how. PLEASE HELP!!!
Old Jan 9, 2003 | 08:02 PM
Shawn C's Avatar
In The Garage
Default Re: A very hard ECU question? (mattcxb18)
damn... thats a strange one. i have no idea. ttt for this one
Old Jan 9, 2003 | 08:09 PM
mattcxb18's Avatar
Default Re: A very hard ECU question? (22lbGS-R)
I just think it is crazy. It isn't like their are any moving parts. It should work in any temp. I open it(the ecu) up the other night everything looked in place ( at the same time i really don't know what i am looking for).
[Modified by mattcxb18, 1:10 AM 1/10/2003]
Old Jan 9, 2003 | 09:23 PM
StormBringer's Avatar
Could be connection fatigue. I see this alot in older projection TV's. Due to the ever changing temps the connections on the board expand and tighten over time they crack the solder connection. Later they will only work when they are hot and expanded completing the broken connections.
I had a similar problem on my 914 like this as well (but not temp dependent), turned out that one of the connecter was not seeting well due to the constant tinkering that I did to the car, a little bit on cleaning of the connectors and everything was as good as new.
Old Jan 10, 2003 | 03:43 AM
mattcxb18's Avatar
Default Re: A very hard ECU question? (StormBringer)
I will try that. Any other ideas?
Old Jan 10, 2003 | 06:51 AM
B18EG6's Avatar
hehe put some of those "toasty toes" foot warmers on there
j/k...Have you considered just getting a new ecu?
Old Jan 10, 2003 | 08:14 AM
YeuEmMaiMai's Avatar
if you are experienced with electronics, take out the ECU and remove the circuit board and check for nonstandard solder joints and repair.
Old Jan 10, 2003 | 09:49 AM
mattcxb18's Avatar
Default Re: A very hard ECU question? (B18EG6)
I have tried that but it did not work
Once the rap gets cold it hold in the cold air.
[Modified by mattcxb18, 2:50 PM 1/10/2003]
Old Jan 10, 2003 | 09:52 AM
mattcxb18's Avatar
Default Re: A very hard ECU question? (YeuEmMaiMai)
I was thinking that but I dont know a trust worthy person to fix it. I cant send it off either( it's my daily driver).
Old Jan 10, 2003 | 02:59 PM
For the time being you could always get a bottle heater and go turn it on on colder days a few minutes before you start the car, that would solve the immediate problem. The best solution would be to find a salvage ECU which hopfully will work, looking for solder failure is a serious pain in the butt, on the other hand a local electronic repair shop, (yes they stilll exist) could very easily go over the board for you in a ew minutes for a nominal charge.
Old Jan 11, 2003 | 11:46 AM
mattcxb18's Avatar
Thanks StormBringer
E.
May 8, 2008 09:58 AM
mugenEGG
Aug 2, 2007 07:25 PM
hondacrxflyer
May 26, 2004 09:27 AM
mattcxb18
Dec 15, 2002 07:27 PM
