Vavles Ticking..what do you think
Old Apr 23, 2002 | 06:52 PM
All Motor EG's Avatar
Default Vavles Ticking..what do you think
I hear some tickin when my car is reving at like 3000rpms... i personaly think i might just need a valve adjustment but i was wonderin if you guys might think anything else.
Old Apr 23, 2002 | 07:52 PM
Prelude Vtec 23's Avatar
Default Re: Vavles Ticking..what do you think (All Motor EG)
How many mile do you have on your car. They recommend to inspect the valves every 15k. Usually ticking is a sign that you need a valve adjustment.
Old Apr 23, 2002 | 08:09 PM
Default Re: Vavles Ticking..what do you think (Prelude Vtec 23)
actualy i only have 2500 on the motor. lsvtec. thats what i was thinkin though i need a valve adjustment.
Old Apr 23, 2002 | 08:41 PM
MrFatBooty's Avatar
Were the valves adjusted correctly when the motor was built?
Old Apr 23, 2002 | 08:43 PM
Kamin's Avatar
Default Re: Vavles Ticking..what do you think (MrFatBooty)
it never hurts to have one done.
Old Apr 24, 2002 | 04:14 AM
tecnic1's Avatar
my fuel injectors are really loud....sounds sorta like valve tapping.
Old Apr 24, 2002 | 06:27 AM
ricodemus's Avatar
Default Re: Vavles Ticking..what do you think (tecnic1)
mine are like that too, because my valves were just adjusted and I still hear the same ticking.
Old Apr 24, 2002 | 10:13 AM
deepnite's Avatar
thought , cept non Vtech motor the valves are self adjusting?..but it could be a lean burn that would give u that tapping sound...might try a higer octane fuel..i prefer Shell cuz its 92 vs others @ 91..but if ur using regular grade now , 87..try the mid grade 89 octane..then maybe the hi one..if this doesnt work..id try a new fuel pump..this is all, of course if ur burning a bit lean at the higher rpms
Old Apr 24, 2002 | 11:15 AM
Default Re: Vavles Ticking..what do you think (deepnite)
right now i use 91 octane and mix with 100. as far as running lean i dont think it is one way to find out is check the spark plugs for white stuff. i just think i need a little valve adjustment . but thanks for the help.
Old Apr 30, 2002 | 11:51 PM
94GSRRacer2's Avatar
New User
it might blow up....
Old May 4, 2002 | 01:45 AM
Default Re: Vavles Ticking..what do you think (94GSRRacer2)
AHAHAH that was about the rookiest call ive heard..... it actualy was just a valve adj.. no more ticking it sounds perfect but i was scared i thought it was going to "blow up".... but no it didnt. =0)
Old May 5, 2002 | 12:48 PM
AzG35's Avatar
That happens quite a bit on a fresh motor. After everything breaks in properly the valves should be readjusted at about 1500 miles.
Old May 5, 2002 | 04:03 PM
pelotudo's Avatar
Default Re: Vavles Ticking..what do you think (AzSi22)
If I've already gotten the valves adjusted, and I still hear the ticking...what would the next step be? I put some of the "valve medic" in it, and they're still tick tick ticking away. I'm guessing maybe injectors. What can I do to get them to stop, and is performance being hurt in any way or just an annoying sound?
jB
GSRVTEC1
Oct 31, 2005 01:19 PM
Baron55
Aug 9, 2005 03:27 PM
TurBoXBirD16
Jun 17, 2002 11:19 PM
DreamSpeed
Jul 31, 2001 11:29 PM
DreamSpeed
Jul 31, 2001 09:36 AM
