Valve lapping compound grit?
Old Apr 30, 2003 | 03:14 PM
IN VTEC's Avatar
Default Valve lapping compound grit?
What coarse and fine grit lapping compound should I be using to lap the valves?
Will 220 and 110 grit be fine? If not, what's the recommended grit?
Old Apr 30, 2003 | 03:28 PM
aeolus's Avatar
Default Re: Valve lapping compound grit? (IN VTEC)
you should be fine with 220.they shouldnt need a rough grit.Most of the time mechanics use the rough stuff first,then the fine stuff afterwards.But usually the fine stuff works good as long as the valves and seats were grinded right.
Old Apr 30, 2003 | 03:45 PM
IN VTEC's Avatar
Default Re: Valve lapping compound grit? (aeolus)
Ok. Thanks. I'll just finish them with 220 then and check the seats.
Old May 21, 2004 | 08:00 PM
XDEep's Avatar
220 seems course, you sure? i was thinking like the 800 or 1000 at least. my exhaust valves had carbon crust all over em. it couldnt hurt right, just like polishing the ports vs leaving the intake ports a little rough for laminar flow. btw do i need oil? i noticed it says to use oil to obtain consistency
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">NAME: Valve Gridding & Lapping Compound - Fine/Coarse
DESCRIPTION: Two duplex containers include 4 oz (108grams) each Coarse Compound for Roudhing and Fine Compund for Finishing. Ideal for seating valves, mating gears, lapping injectors and honing knives. Mix compound with oil to obtain desired consistency. Use with CTA Lapping Tools.
fatpride111
29
Nov 14, 2008 09:01 AM
ToeJam
May 2, 2007 08:28 PM
user 98292739
Apr 17, 2005 08:22 PM
menkio
Jul 23, 2004 12:27 PM
jdub db8
May 4, 2004 08:32 PM
