Cleaning carbon off of valves?
Old May 2, 2004 | 06:22 AM
jdub db8's Avatar
Default Cleaning carbon off of valves?
I am about to introduce my b16 head to my newly built b18c1 botttom
Well, my valves are coated with carbon, pretty thick (00'SI head, 50k) I was wondering how i can get them back to bare metal?
TIA-
Old May 2, 2004 | 06:24 AM
menkio's Avatar
Default Re: Cleaning carbon off of valves? (Jester_Si)
good question, i would like to know as well
Old May 2, 2004 | 06:32 AM
Frozen E's Avatar
H-T White Ops
Pull the head appart (make sure you keep track of what valve came from where) and use some gun cleaning solvent. CRL or CLR is what it's called. Use a brass bristled brush to do one valve at a time. Tedious, but it'll do the job. Hell, might as well give the valve seats a makeover too since you're going to have it all appart anyway.
Old May 2, 2004 | 06:41 AM
jdub db8's Avatar
Default Re: (IslandSi)
okay, is there any way to clean the face of the valve. I didn't want to pull it aprt until i replace the valves-
Can you use solvent and the brush on just the face... with the valves still in the head?
Old May 2, 2004 | 07:10 AM
PM-Performance's Avatar
Default Re: (Jester_Si)
i used brake cleaner and like a small brush or something to brak the stuff loose.then put a polish bit on my dremel and cleaned it allup nice
Old May 2, 2004 | 07:18 AM
DaX's Avatar
DaX
Loved
Community Favorite
Sea Foam it maybe?
Old May 2, 2004 | 07:43 AM
jdub db8's Avatar
Default Re: (DaX)
I am going to give it a shot with the dremel- I'll post some before and after pics!
Modified by Jester_Si at 1:31 PM 5/2/2004
Old May 3, 2004 | 03:52 PM
jdub db8's Avatar
pics of when i started-
I will post pics after i am done too. So far i can say- brash brush, carbon steel brush, brake cleaner, sea foam, aircraft remover...don't do ****. I found a very fine sanding disc that does wonders- (brass brush for a nice finishing touch though)
Old May 3, 2004 | 04:00 PM
importboi22's Avatar
thats how mine looked, turned the head over, poured seafoam in the chambers and let it sit, put more seafoam every 30 mins or so after about 3 hours hit it with a brass BBQ cleaning brush..... looked perfect
Old May 3, 2004 | 04:07 PM
piscorpio's Avatar
A friend of mine just took his head to a machine shop. They checked and cleaned it for around 100 bucks, and it looks brand new. Probably much cheaper to clean it yourself, but just throwing the option out there.
Old May 3, 2004 | 05:37 PM
jdub db8's Avatar
Default Re: (importboi22)
i tried sea-foam. Now i am just going to polish them- Have some time to kill anyway-
Old May 3, 2004 | 05:49 PM
rioninja's Avatar
Two words for you-> OVEN CLEANER.
Spray it on, wait then minutes, carbon wipes off.
Just be careful you dont leave any carbon deposits on the valve seats,
since it tends to come off in fairly large flakes.
Old May 3, 2004 | 06:03 PM
MiraiZ's Avatar
I can get you some of this stuff....don't know how effective it really its though:
here's a slide show:
click!
Old May 3, 2004 | 06:32 PM
racinskittle's Avatar
Default Re: (MiraiZ)
If you have a grinder use that wire brush thing next to it. That's how they were doin it at the machine shop I went to and they came out purty
Old May 3, 2004 | 06:41 PM
b16ahybrid's Avatar
Default Re: (racinskittle)
Not sure what method your going with but just make sure you don't leave any sharp edges.....
Old May 3, 2004 | 06:42 PM
Warriortch's Avatar
I have always used the wire bursh wheel on the bench grinder. The oven cleaner looks to be a good alternative if you don't want to take the valves out. Just use the wire brush with caution
Old May 4, 2004 | 04:48 PM
jdub db8's Avatar
This is mid point, i bought a dome shape polishing bit tonight to finish the inner portion.I also got a big disc to hit the tops again and make them uniform. Coming along pretty good-
I am leaving the intake valves alone? (other than a good cleaning)
Old May 4, 2004 | 08:32 PM
92HB_HB's Avatar
a wire wheel on my die grinder did the job for me... man it practically looks brand new...
s.cha
Dec 21, 2009 10:01 AM
vtecn8ive
Sep 19, 2008 01:23 PM
7rrivera7
May 2, 2004 12:53 AM
BeerMan
Jan 27, 2004 10:11 PM
KooK
May 22, 2003 07:23 AM
