valve cover gasket sealant
Old 06-20-2002, 01:17 PM
GSR44's Avatar
Default valve cover gasket sealant
hey guys...i plan on doing a valve adjustment this weekend and i will also be replacing my valve cover gasket. my friend changed his valve cover not too long ago, but he used a generic brand gasket sealant instead of honda bond. the instructions for the sealant said that it would take about 24 hours for it to cure, and he didnt drive his car till the next day. was that really necessary? is it the same w/ the honda bond or can i just drive it once i'm done?
btw...engine is a b18c1
GSR44 is offline
Old 06-20-2002, 01:54 PM
HOND PWR's Avatar
Default Re: valve cover gasket sealant (GSR44)
I used Honda bond on my GSR valve cover with no leaks. Thats what Honda uses, they drive the cars with out waiting for it to dry. You should have no problems.
HOND PWR is offline
Old 06-20-2002, 01:56 PM
sgT
sgT's Avatar
Hondabond/permatex ultra gray has a cure time of about 15-20 minutes
sgT is offline
Old 06-20-2002, 02:05 PM
keebler65's Avatar
Default Re: valve cover gasket sealant (sgT)
where is hondabond sold? just at the dealership?
thanks
keebler65 is offline
Old 06-20-2002, 02:10 PM
sgT
sgT's Avatar
Default Re: valve cover gasket sealant (keebler65)
get hondabond from the dealer or permatex ultra gray from any parts store
sgT is offline
Old 06-20-2002, 04:43 PM
New User
4wsB21a's Avatar
if you are putting on a new valve cover gasket there should be no need for any kind of sealant. the gasket is supose to be doing the sealing. if you have a problem with it sealing, then it is more serious than your gasket. you do not need to put on any kind of silicone when doing valve cover gaskets.
4wsB21a is offline
Old 06-20-2002, 05:57 PM
GSR44's Avatar
Default Re: valve cover gasket sealant (crxplus)
you sure about that one? it even says in the helms manual to apply liquid sealant to the appropriate points on the gasket.
GSR44 is offline
Old 06-20-2002, 06:05 PM
Mikey3000's Avatar
i agree. none needed.
Mikey3000 is offline
Old 06-20-2002, 07:26 PM
GSR44's Avatar
Default Re: valve cover gasket sealant (Boss Hogg)
hmmm....well, if it's worked for the both of you, i cant disagree...but i think i'd rather take the safe route and follow what the service manual says by using the liquid sealant.
GSR44 is offline
Old 06-20-2002, 09:17 PM
Aceman64's Avatar
Hey man put hondabond on the corners of the gasket where there is a wider spot for it. The service manuals dont say to put it on there for nothing. The spots where it says to put it are prone to leaking oil. True it wont happen to everyone, but do you want to be the one it does happen to? I can tell you mine has never leaked, but i always put it on.
-Ace
Aceman64 is offline
Old 06-20-2002, 09:19 PM
the DR.'s Avatar
ok.. try doin it without any sealant.. then... when your car leaks oil (it will) put some permatex on the edges. the edges where there the arch for the cam, just put a little goop on each edge then put the valve cover back on
the DR. is offline
Old 06-20-2002, 10:14 PM
that SCION girl's Avatar
Default Re: valve cover gasket sealant (CIVICtypeS)
hondabond !!!
that SCION girl is offline
depo
03-23-2019 09:37 PM
dc5tegk20
08-24-2006 12:40 AM
crx_88_si
07-29-2004 08:47 AM
02 coupe
09-19-2003 10:28 PM
GSR44
06-22-2002 02:11 PM
Quick Reply: valve cover gasket sealant
