Valve Clearance Adjustments?
Old Mar 4, 2004 | 05:57 PM
DelSolSi93's Avatar
Default Valve Clearance Adjustments?
Hey guys I just have a question on my D16z6, I know after so many (I dont remember exactly how much) miles you have to get your valve clearances checked, is this something I can do or how hard is it?
Old Mar 4, 2004 | 08:15 PM
warchild69's Avatar
Default Re: Valve Clearance Adjustments? (DelSolSi93)
not hard at all just takes a little time.... do it with the engine cold... (sitting over night!) just get the spec's from a hanes manual or whatever..... set the engine at TDC for cylinder #1 and adjust the valves for thatcylnder.... then turn crank over 180 deg. and set #3 then rotate again 180 to align tdc marks and do #4 then 180 and adjust #2..... very easy and you will notice instant results if your valves needed the adjusting.... get the feeler gauges you need from any auto store... advance, auto zone, pep boys, checkers what ever like $4.00.... also if you want more info you can go to the parts stores and just read the book and take notes....if you need to.... i do!
Old Mar 4, 2004 | 09:20 PM
DelSolSi93's Avatar
Default Re: Valve Clearance Adjustments? (warchild69)
Are the marks for TDC on the cam sprocket?
Modified by DelSolSi93 at 6:38 PM 3/5/2004
Old Mar 6, 2004 | 09:24 PM
InjectedPerformance's Avatar
We sell parts.
Check and preform the lash warm to the touch. Around 105 degree. The fireing order is 1,3,4,2 of course. Put TDC, check #1. Put a screwdriver in # 3, rotate crank counter clockwise, get it till the screwdriver goes all the way up. Check it. And so on.
Old Mar 6, 2004 | 10:25 PM
Emong3's Avatar
You can just open your distributor cap and rotate the crank shaft till the rotor piont to#1 sparkplug
Old Mar 6, 2004 | 10:51 PM
We sell parts.
Default Re: (Emong3)
Why open the dist. cap. He can see the cam gears align with the markings. TDC! He is not trying to find fireing order. Next is take the timing belt cover off, right. LOL. Ok, just buy a manual for basic service. It is your best friend.
Hybridize
Apr 21, 2008 02:19 AM
zach1288
45
Apr 17, 2007 06:40 PM
Dat_One_Si
Sep 23, 2006 07:43 PM
T-sohctec
May 14, 2003 06:30 PM
aet6
Aug 10, 2002 02:14 AM
