VAFC settings for a d16z6
Old May 12, 2004 | 01:00 PM
DjFreeze's Avatar
Default VAFC settings for a d16z6
Any info on the settings people are using a VAFC with a sohc vtec. ive done plenty of research and understand bringing it to a dyno would be best! but for now what should i set some things to. Also i want to richen my motor a bit, since its running real lean! Any tips would be great!
Old May 12, 2004 | 02:28 PM
Ekasey's Avatar
Default Re: VAFC settings for a d16z6 (DjFreeze)
on you wide open throttle map i would richen it up to a max of 6 % starting from the lowest rpm point and progressing gradually and as far as VTEC goes 5500 is fine
Old May 12, 2004 | 05:39 PM
DRG Performance's Avatar
Default Re: VAFC settings for a d16z6 (eLusive ek4)
6 % across all RPM points?
Old May 12, 2004 | 07:54 PM
boostn420's Avatar
Default Re: VAFC settings for a d16z6 (DRG Performance)
plus 6& across all rpm points in the high throttle, after vtec.
I used to run mine and plus 5 and finish at 7 in the high throttle and run -3% for cruise and low end fuel economy. And -7 across the whole damn thing and vtec on at 9k for smog checks and dont forget to hide it.
Old May 12, 2004 | 08:04 PM
EJ1 wilcox's Avatar
Default Re: VAFC settings for a d16z6 (boostn420)
Is it safe to play around with the settings without a wideband?
I had a friend blow his engine because he altered his settings too much without proper tuning.
Old May 12, 2004 | 09:17 PM
boostn420's Avatar
Default Re: VAFC settings for a d16z6 (koreanwilcox)
Yes, its safe. you shouldnt be able to blow your motor with a VAFC alone, maybe with boost but you'd still have to be retarded to do it. Just dont go negative in the settings and youll be fine. If the car has to correct over 15% it throws a CEL so dont adjust too far over 15%.
The *** dyno will prove more valuable than you think if you pay attention to your car. You can tell the difference in power when setting vtec engage points, you can feel when it makes more or less power and get it set up pretty decent.
Old May 12, 2004 | 09:46 PM
intenseEK's Avatar
yo anthony, refund my money yo.
Old May 13, 2004 | 04:33 AM
DjFreeze's Avatar
Default Re: VAFC settings for a d16z6 (intenseEK)
so what would be optimal settings to pass emmisions. im right now failing NO
Reg: 1124
My #'s :1870
I know my cars running real lean. What could i do to pass?
Old May 13, 2004 | 07:05 AM
Ekasey's Avatar
what # is at 1870 can you give me nox hx and co emmisions readings one number doesnt tell the whole story
Old May 13, 2004 | 07:14 AM
EJ1 wilcox's Avatar
This morning on the way to school I set my VTEC @ 5500 and corrected to +6% after VTEC on the wide throttle settings...
butt dyno gives it a
Old May 13, 2004 | 07:35 AM
Ekasey's Avatar
your welcome ^_^
Old May 13, 2004 | 08:34 AM
DjFreeze's Avatar
Nox ive been failing for. i know my cars running real lean, so should i go -% or +%
Old May 13, 2004 | 09:15 AM
Ekasey's Avatar
PLUS ALWAYS PLUS WITH NOX, Usually nox is created by a lean condition. combustion pressures being excesivley high and temrature in excess of 2500 degrees farenheit is when nox is actully created so essntially you wanna cool your combustion chmabers down with mroe fuel but not to much to the point of where you fail other emmisions. Make sure your cat is functioning properly too if you are fialing emissions get it really hot and then with a temp gun check the inlet temperature and the outlet, the outlet should be rough2degrees hotter if the c is functioning correctly
Old May 13, 2004 | 05:05 PM
intenseEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intenseEK &raquo;</TD></TR><TR><TD CLASS="quote">yo anthony, refund my money yo. </TD></TR></TABLE>
Old May 14, 2004 | 09:33 AM
regime's Avatar
give him his money back... and give me my turbo
Old May 15, 2004 | 06:45 AM
crxsirvtec's Avatar
NEVER BUY FOR THIS GUY VERY VERY VERY VERY VERY VERY BAD SELLER!!!!
anyone live in the new jersey area, want to go beat his ***??
Old May 25, 2004 | 08:16 AM
1992delsol's Avatar
Hey,
How good is the VAFC?
Does it remove the japanese speed limiter?
I recently had a new exhaust fitted and removed CAT, car now seems to be using more petrol, can this be controlled by the VAFC?
Cheers,
Chris
Old May 26, 2004 | 03:59 PM
regime's Avatar
Default Re: VAFC settings for a d16z6 (crxsirvtec)
finaly got my turbo after over 2 months.... hope everything works out for everyone else also
toooslow
Oct 9, 2005 05:59 AM
94vtecmn
Apr 23, 2004 05:30 AM
89dxhunchback
Sep 27, 2003 02:47 PM
Sirex
Mar 4, 2003 05:25 PM
