VAFC 2 owners please help
Old Oct 8, 2005 | 04:09 PM
toooslow's Avatar
Default VAFC 2 owners please help
I just returned from getting a smog check and im running too rich on my chipped p72. I ordered a VAFC 2 to try to lean the mix out because i dont have a stock ecu. The smog tests were held at around 2000 rpm +\- 200 rpm and 2500 rpm +\- 200 rpm for about 45 seconds each. I was reading the online manual for the vafc and was a little confused. Can i adjust fuel under 3000 rpms? since the tests are tried under normal drivng conditions with throttle probably like at 10% would i change fuel through the Wide thr, the Narr. Thr or the NE-p:lvt? Thanks
Old Oct 9, 2005 | 05:59 AM
gottagofaster's Avatar
Default Re: VAFC 2 owners please help (toooslow)
I too am running a VAFC-II. It is adjustable starting at 1000rpms. You wouldn't need to adjust the HVT setting for normal driving conditions. HVT would be the settings used after v-tec engagement. To get started you'll probably want to set your throttle to 50/50. Up to 50% throttle you use the Narrow throttle settings. Above 50% you will switch over to the Wide throttle settings. Both wide and narrow have LVT and HVT settings (no-vtec/vtec) you'll want to adjust your narrow throttle setting's LVT portion to negative numbers (depending on how much air you need to add) starting at 1000rpms and increasing toward 0 as you approach vtec engagement. If you plan on hitting v-tec during the emissions test, then adjust the HVT settings of the Narrow throttle portion. You'll have to play with it a bit as I did and MAKE SURE YOU FOLLOW THE DIRECTIONS EXACTLY when first setting up the VAFC-II. You can damage your ECU if you are not careful. Hope this helps. Let me know if it doesn't and I'll try to break it down better.
gamakichi77
Oct 26, 2003 11:16 PM
98R-1144
Jan 2, 2003 07:25 PM
CPR
Oct 2, 2002 10:37 AM
IgniteTeg
Apr 26, 2002 07:55 AM
IgniteTeg
Apr 25, 2002 11:25 PM
