Vafc problem no vtec
Old Feb 4, 2003 | 05:08 AM
COLORPROS's Avatar
Default Vafc problem no vtec
I thought my fuel tuning was way out of wack on my vafc.I called a freind and he told me to initalize it.I did.The only problem is that my vtec wont come on.I have the vtec set at 5600 but it just doesn't come on.I dont know much about the vafc but I see alot of other things you can tune that have vtec in the disciption.Any help will be greatly appriciated.
Old Feb 4, 2003 | 05:21 AM
b16 pwrd ek's Avatar
Default Re: Vafc problem no vtec (COLORPROS)
check your wiring i had the same problem with my v afc and my vtec wire from my v afc had came loose
Old Feb 4, 2003 | 05:30 AM
COLORPROS's Avatar
Default Re: Vafc problem no vtec (b16 pwrd ek)
I will check for that.Thanks
Old Feb 4, 2003 | 07:03 AM
COLORPROS's Avatar
BUMP
Old Feb 4, 2003 | 08:03 AM
nolimits's Avatar
First monitor vto above engagement point to see if the vafc is sending signal. If ok, put a voltmeter or test light on the vto (output) wire and see if you get a reading @ 5600. If all is well there then your problem may be a solenoid or physical limitation.
Old Feb 4, 2003 | 09:29 AM
COLORPROS's Avatar
Default Re: Vafc problem no vtec (nolimits)
I fixed it.When I initalized it I didnt set it back up in 4cyl mode.All is good now.Thank you for those who tried to help.
CpRiCe87
Feb 11, 2006 11:42 AM
2fknlo
Feb 2, 2003 08:15 PM
The Poopsmith
Aug 15, 2002 05:18 PM
The Poopsmith
Aug 9, 2002 10:18 PM
Renegade
Feb 13, 2002 12:08 PM
