VAFC and MAP (CEL 3) Codes With Many Mods - Help?
Old Feb 22, 2004 | 01:07 PM
Ruby Civic's Avatar
Default VAFC and MAP (CEL 3) Codes With Many Mods - Help?
OK, I am still learning and have VTEC up and all the connections double checked:
I have b18c built with 12.1 compression, 70 mm tb, intake , jdm 4:1 header, Toda B cams, port and polish head, etc.
have not run on air - fuel/dyno but seems to be starved for fuel top end with idle fuel press. at 47 lb
since so far i have only 240 cc injectors i tried to richen up the top end (ie 45% on the VAFC at 8k rpm) - this triggers a code which does not occur at only 12% enrichment
would it be normal to throw the MAP code at top end?
i know, got 320cc injectors to go in soon
Old Feb 22, 2004 | 03:28 PM
boostn420's Avatar
Default Re: VAFC and MAP (CEL 3) Codes With Many Mods - Help? (Ruby Civic)
You should increase the fuel pressure and bring down your fuel adjustment %'s on the vafc. This should help you across the whole rpm range because you have such high compression anyway. The computer will through a code after it has to correct past 15% to be happy with the o2. Try not to make such big changes on the vafc because it also affects your timing.
Old Feb 22, 2004 | 05:52 PM
Ruby Civic's Avatar
Default Re: VAFC and MAP (boostn420)
hmmm, sounds like the next move, but will my idle be a problem? funny how you can tell when a motor is on the edge of something really good powerwise and i think this is it
maybe try to bump the press about 5 psi to start and see what happens
i thought this might be the case but on the learning curve
Old Feb 22, 2004 | 05:53 PM
Ruby Civic's Avatar
Default Re: VAFC and MAP (Ruby Civic)
ps it was kina funky with a little ignition breakdown near to vtec x-over too
DarkBB4
Dec 12, 2004 11:56 AM
superturboprelude
Nov 4, 2004 05:39 PM
johnzm
Dec 26, 2002 05:30 AM
Turbohatch
Sep 23, 2001 04:59 AM
