VAFC HELP.. plzzzzzzzz....
Old Jun 13, 2003 | 01:14 PM
FastNFurious
Guest
Posts: n/a
Default VAFC HELP.. plzzzzzzzz....
Just installed a drag turbo kit, vortech FMU, rc 440cc injectors, AEM FPR and RAIL, VAFC in a 95 Integra GSR. The car is really rich. Can anyone help me out with the VAFC settings??? I just installed it and am clueless looking at the instructions.
I set the sensor to 6, 6
The car is set to 4 and the diagonal up arror.
I know the car needs to be dyno tuned to have the correct settings but I have to cut out some of this fuel to get it there. The engine is throbbing back and forth like crazy, Heh. I promise I won't race it and I will keep the boost to a minimum, I just need some help with setting it so I can drive it.(haven't driven it for 3 months
Thank you
Old Jun 13, 2003 | 08:46 PM
FastNFurious
Guest
Posts: n/a
Help me out.............
Old Jun 18, 2003 | 10:35 PM
Fired Honda's Avatar
Hey david...Ya got the same setup as mine..I just install the Drag too..but no injector though...Going 440cc next week..
But anyways, come to your question..you got a VAFC right...First question how much boost you will to run with the VAFC...cause you can run up to 10psi of boost...and no more after that cause you using VAFC....And you have everything come with the Drag kit install right? I mean fuel pump, too...???
Post up how much boost you willing to run then I send you the setup...hopefully it works on ur car...
Modified by Fired Honda at 7:55 AM 6/19/2003
stockb18c
Oct 24, 2006 04:55 PM
xTuRboTeGgYx
Oct 1, 2003 06:00 PM
FastNFurious
Jun 15, 2003 11:09 AM
