vafc help
Old Nov 14, 2001 | 08:59 AM
Doctor CorteZ's Avatar
Default vafc help
i need to know if i can just tap into the oil pressure sensor on the back of the block for a non-vtec to v-tec swap on a 91 civic si- heres the setup
91 civic hb si
92 civic d16 vtec swap
91 si non vtec ecu
vafc
i need to get the vtm wire and i'm finised i just dont know how to get a proper signal
also , will this thing engage vtec on its own without a signal from the ecu ?
and lastly, on the solenoid for vtec there's 3 plugs
1 comes from the plunger looking device w/1 pin
the other is on the solenoid itself with 2 pins , is this solenoid input and ground or something else
thanks for the help in advance
91SOHCSI
12
Apr 7, 2008 10:53 AM
90b20vtec
May 11, 2006 09:04 AM
kolk1
Jun 19, 2003 07:53 PM
Doctor CorteZ
Nov 15, 2001 09:17 AM
Doctor CorteZ
Nov 14, 2001 10:23 AM
