vafc and 310's
Old Apr 28, 2003 | 09:49 AM
turbodsmpower's Avatar
Default vafc and 310's
I have a vafc in my 91 hatch car is still obd0 and i have 310's but everytime i lower at 1000 rpm the fuel enough shouldnt the car like almost die. It doesnt seem to be adjusting fuel. Does anyone know what could be wrong the rpm works and vtec works. Also the throttle postion reads backwards it reads 100% at ideal and when i stomp on it goes to 0.
Please help
Old Apr 28, 2003 | 03:44 PM
Default Re: vafc and 310's (turbodsmpower)
ttt
Old Apr 28, 2003 | 05:00 PM
dfoxengr's Avatar
did you wire it correctly? and how much % are you lowering the fuel output?
Old Apr 29, 2003 | 03:38 AM
Default Re: vafc and 310's (hybridvteceg)
i can raise it up to 50+ or - and it doesnt change ideal at all. thats why i think its not altering fuel. Does anyone have a diagram i can follow for obd0 car.
Old Apr 29, 2003 | 04:26 AM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodsmpower &raquo;</TD></TR><TR><TD CLASS="quote">I have a vafc in my 91 hatch car is still obd0 and i have 310's but everytime i lower at 1000 rpm the fuel enough shouldnt the car like almost die. It doesnt seem to be adjusting fuel. Does anyone know what could be wrong the rpm works and vtec works. Also the throttle postion reads backwards it reads 100% at ideal and when i stomp on it goes to 0.
Please help </TD></TR></TABLE>
did you wire this in yourself or what??
http://www.spipowerexcel.com/pdfs/vafc.pdf
the manual is your friend.
the last part about the throttle is because you didnt follow the directions in the manual. you did the opposite of what you should have.
Old Apr 29, 2003 | 07:58 AM
pills_PMD's Avatar
you're initial settings are fucked.
you want it to be 4cylinder with increasing throttle, so make the little arrow piont /^ that way. arrow going toward the top right.
Old Apr 29, 2003 | 08:16 AM
Default Re: (pills_PMD)
it is set that way im going to probably soder all the wires together and see if that works
Old Apr 29, 2003 | 08:18 AM
Default Re: (turbodsmpower)
but shouldnt it kill the car or make it idle different if i take too much fuel out at idle
Old Apr 29, 2003 | 12:07 PM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodsmpower &raquo;</TD></TR><TR><TD CLASS="quote">but shouldnt it kill the car or make it idle different if i take too much fuel out at idle</TD></TR></TABLE>
if all of your wiring is correct, then yes.
Old Apr 29, 2003 | 06:01 PM
Default Re: (sleeper4dr)
ok i got it to work but it works at wide it pulls fuel out at idle and at narrow it pulls at full throttle
Old Apr 29, 2003 | 06:08 PM
dfoxengr's Avatar
you can set it at diff RPMs incase u set it all the same
Aracheon
Apr 23, 2005 05:56 AM
Flux
May 20, 2004 10:56 PM
GsTeg90
Apr 8, 2003 08:23 PM
EK9Blitz
Oct 3, 2002 10:52 PM
speedworks
Jul 29, 2001 10:23 PM
