V-AFC Help
Old Aug 14, 2003 | 02:57 PM
nevin's Avatar
Default V-AFC Help
I just bought a used V-AFC and in the instructions I dont see anything for the crx ecu. Does anyone have a pinout of the crx ecu with the colors of the wires and their function? Or better yet I only need the pin number and color of the following:
1-IG Power
2-Ground
3-RPM Signal
4-Throttle Signal
5-Pressure Signal
6-VTM Signal(Don't know what this is, don't think I even have it)
Any help would be great thanks!
Old Aug 14, 2003 | 03:47 PM
Patch's Avatar
Default Re: V-AFC Help (nevin)
Why are you hooking up a VTEC AFC on a non-VTEC car? You're only asking for trouble...
You should have just bought a SAFC.
Old Aug 14, 2003 | 04:25 PM
PhatOptimo's Avatar
What ecu do you have?
Old Aug 14, 2003 | 04:26 PM
nevin's Avatar
It dosen't matter... It modifies sensor input and output, I just woln't run vtec lines. Anyways I didn't even say I wasn't hooking it up to a vtec motor, but I am and plan to get a b16 head soon anyways so buying a s-afc would be a waste of money.
edit: Found what im looking for in the S-AFC manual.
Old Aug 14, 2003 | 08:08 PM
sslude's Avatar
Default Re: (nevin)
VAFC can be used on a non-vtec car...safely. the only difference is taht you wont be hooking up any lines for vtec, and you will only be tuning air/fuel ratios, not VTEC.
Old Aug 14, 2003 | 09:15 PM
nevin's Avatar
edit-sorry i hit refresh
wicked_b16eg
Dec 30, 2007 11:10 AM
Power Rev Racing
Oct 16, 2005 06:10 PM
Tarlacon
Apr 4, 2005 03:49 PM
USDM 4G VTEC
15
Oct 10, 2003 08:19 PM
TurboB18C1
Nov 25, 2002 06:11 PM
