Which ump ls/VTEC
Which oil and water pumps will compatible with an B18A/B block? I'm trying to find out if I can use any of the B16 oil pumps I have lying around.
[Modified by FFgeokstar, 7:35 PM 12/5/2002]
i wouldnt use just any pump...definetly use a VTEC water pump with the matching timing belt and a VTEC oil pump as well, the stock LS pumps are not reliable once you throw a VTEC head in the mix...HTH
[Modified by CC94B18, 10:02 AM 12/6/2002]
GSR/ITR/B20 all have the same flow rate. (use one of these)
LS has the lowest flow rate. (dont use this one)
EDIT: Sorry, I was referring to oil pumps.
[Modified by Jeff C, 1:53 AM 12/8/2002]
A ls pump takes less hp to spin. but it flows less. I have had one for over a year now with no overheating problems. Ran ac going uphill in 100 degree plus heat too.
