Uberdata & Ostrich Problems
Old Apr 15, 2005 | 03:11 PM
mattEG's Avatar
Default Uberdata & Ostrich Problems
So yea, I posted this over on uber forums but no answer yet, figured I'd give this place a try.
I'm fresh out of ideas.
I've tried everything that people have listed here and I still get a CEL every time I start the ruddy car.
I've tried both versions of the firmware with both versions of uberdata... OST2 and 1.8LE and I get a CEL everytime without fail... I've tried three different chipped ECU's that all work if I burn the rom to the chip and put it in... I have live edit always unchecked, I"ve had to build a map from the GSR base because the LS base is corrupt apparently... STILL getting CEL's...
Anyone have ANY idea of what to do?
Setup is as follows:
Chipped P06
D15b7
Thats really all that should matter right?
I can flash the firmware on the ostrich no problem so I assume that means it is probobly aok right?
I'm willing to try just about anything.
EDIT: Just spent another hour and a half trying to get it to work. No go. Tryed both versions of UD, everything I could find on this forum, and still nothing.
Is there a version of the LS rom that I can use to make a stock rom for a d15b7? Or do I have to go throug the opening the GSR map and importing po6 and then editing everything else? That doesn't work either. I'm beginning to think that the ostrich itself is toast. I have no idea. Almost quitting time.
Anyone?
Old Apr 15, 2005 | 06:11 PM
hondaguyef's Avatar
Default Re: Uberdata & Ostrich Problems (mattEG)
Are you using the VTP disable option? If not, there is your problem.
Phil
Old Apr 16, 2005 | 06:58 PM
mattEG's Avatar
Hahahaha, after all that trouble it WAS the VTP disable..
Thanks alot man!
Old Apr 17, 2005 | 03:41 AM
hondaguyef's Avatar
Default Re: (mattEG)
No prob dude. If you have any other questions just PM me. Later.
Phil
Old Jul 22, 2005 | 02:21 PM
RudeLude's Avatar
Default Re: (hondaguyef)
whats the VTP?
91b18a1ls
Engine Management and Tuning
Apr 14, 2012 01:59 AM
kyden
Sep 24, 2011 06:39 AM
HiProfile
14
Sep 1, 2008 06:52 AM
asianspeed
Oct 11, 2006 03:02 PM
