two-wire to one-wire horn conversion
Old Oct 24, 2009 | 12:57 AM
numba1stunna201's Avatar
Default two-wire to one-wire horn conversion
i've been trying to get a set of one-wire horns to work on my '95 eg with no luck. H-T i need help !!!!!! and please i need step by step pref. w/ pics im a newbie
Old Oct 25, 2009 | 12:54 PM
Default Re: two-wire to one-wire horn conversion
NOBODY ???????
Old Oct 26, 2009 | 03:33 PM
PStalls's Avatar
I can't find any either........
Old Oct 26, 2009 | 03:38 PM
night's Avatar
hmm.. off the top of my head without digging up wire diagrams, 2 wires use a relay. 1 wire has always-on power to the horn through the steering wheel and the ground is the housing bolted to the body.
did your horn not work before?
Old Oct 27, 2009 | 02:48 AM
yeah the horn worked fine but i just want a different sound so i took off a set of CL type-s horns when i was junkyard diving
Old Aug 16, 2011 | 01:04 AM
JDM_addict's Avatar
got to bump this old thread....
I got the same problem.
I got a 1 wire horn to hook up to my 2 wires horn harness on my car,
I tried to connect the 1 wire horn to either one of the 2 wire harness, but no luck..
Old Aug 16, 2011 | 06:11 AM
fcm's Avatar
fcm
Old Fart
Simple, the one wire horn is grounded when mounted, 12V+ must be supplied to the one wire.
Test the two leads of the two wire plug to see if the 12V+ is the switched lead, on when horn button pressed, if so connect that lead to horn wire, if on the other hand it is the ground lead that is switched you will need a relay to switch polarity.
What is the MM&Y of the car? 94
Old Aug 16, 2011 | 07:08 AM
JDM_addict's Avatar
car is yr 96, horn came from 99 civic sedan
Old Aug 16, 2011 | 05:20 PM
fcm's Avatar
fcm
Old Fart
96 what, Ford Pinto?
The horn on the 99 Civic is driven by a relay, [like a lot of Honda/Acura and most other cars] the horn button supplies the horn relay with a ground, [#85 pin on relay] the relay supplies the horn with 12V+ , the horn is grounded through it's mounting, the only real diff. with a 2 wire system is the ground is also supplied by a wire.
Some horn systems the 12V+ is supplied directly to the horn and the ground is switched, always a 2 wire system. 94
Old Aug 16, 2011 | 08:16 PM
JDM_addict's Avatar
96 civic ek
so in order for me to run the 1 wire horn with my 2 wires plug, i need to have a relay is it? i though the 96 had a relay alrdy?
Old Aug 17, 2011 | 06:01 AM
fcm's Avatar
fcm
Old Fart
A 96 Civic does have a horn relay, all you need to do is mount the horn and connect the horns one (1) wire to the correct lead in the two wire plug, sorry, I do not have a wire color, but only one of the leads in the two wire plug will work, the other is a ground. 94
Old Aug 17, 2011 | 04:14 PM
JDM_addict's Avatar
i tried that before, no luck. after thinking, it doesnt look stock eventho it work, so yesterday i bought a 2 wires 2nd hand horn from chopshop to solve my problem. i don know if it's originally for civic. on the horn it has 'mitsuba' brand one it, and say 110dB. is it a standard one for civic 96?
Old Aug 17, 2011 | 04:39 PM
fcm's Avatar
fcm
Old Fart
Don't know, what model of 96 Civic, EK would make it a JDM right hand drive, I'm guessing it is not a JDM Civic.
Anyway, as long as the horn works and you can mount it, your good to go. 94
Old Aug 17, 2011 | 04:50 PM
JDM_addict's Avatar
is a ek2 JDM rhd.
Old Aug 18, 2011 | 05:58 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by JDM_addict
is a ek2 JDM rhd.
Doh!! just noticed your located in Malaysia.
So does the horn work?
Old Aug 18, 2011 | 06:46 AM
JDM_addict's Avatar
lol....u dont feel my english is a bit poor? hahah
ya, it works, just that i dont like the sound. It sounds like a small car honking for a way.... haaha...
Old Aug 18, 2011 | 09:54 AM
fcm's Avatar
fcm
Old Fart
lol....u dont feel my english is a bit poor? hahah.
LMAO, Have you read some of the posts here by English speaking people, your English is pretty good and compared to others it is very good. 94
Old Aug 18, 2011 | 05:19 PM
JDM_addict's Avatar
haha.. not really, i read alot in here, but most of them are using 'internet language' haha which we all know what it means.
Old Aug 18, 2011 | 07:18 PM
b20z123's Avatar
I myself have a similar problem. I have a 2000 automatic integra. I converted it to manual with a b20z and a type r lsd tranny. Car revs fine with auto ecu obd2.However I converted it to obd1 with an obd2b to obd1 harness alongside a 1995 obd1 p75 manual ecu. And now the car wont rev pass 5500. It hits 5500 but then just goes down and picks up again. The problem only persists while with in obd1?
How do I fix this?
Thanking you in advance
Old Aug 18, 2011 | 09:04 PM
JDM_addict's Avatar
How do I fix this?
wrong thread bro.
MiamiEgGSr
Oct 21, 2007 07:11 AM
dylokjai
14
Oct 13, 2006 01:10 PM
integraXTC
Aug 4, 2005 08:27 AM
streetstylenperformance
Feb 26, 2004 03:28 PM
