How do I wire a new horn button?
My horn doesn't work and I haven't been able to find out why. So now I'm trying to wire the horn (the stock one) to a horn button on my dash. My problem is I don't know wiring. How do I wire this up, do I cut the harness that goes to the horn and connect some new wires to the cut harness? Do I need a relay, anything else?
Re: (integraXTC)
You need a "switch" or a botton-type switch.
There's two wires going into the horn.
Make a ground somewhere around the horn, wire that to the horn.
Then find a 12V source, wire that to the switch (first connector), then from the second connector, wire that to the horn (power to the horn). Done.
Can't beat new wiring reliability.
Re: How do I wire a new horn button? (integraXTC)
check and see if your horn is working. same thing happened to my 240 and it turned out that the horn was borken. just wire a wire form your battery to the horn and see what happens.
super_mut
Audio / Security / Video
02-09-2006 04:40 PM
