Two vtec engagements in less than a second?
Old Dec 5, 2003 | 10:59 PM
VtecDA9's Avatar
Default Two vtec engagements in less than a second?
When I hit vtec (4500) sometimes the vtec will sound like it engages twice within less than a second apart???
Also, I could be driving in 5th gear and it seems like there is a lil troube with vtec when engaging, some sputtering.
I am running a vision chipped p28 brain for my 11.6 ls/vtec. Fuel pressure is at 44psi at idle.
Again, not all the time.
Old Dec 5, 2003 | 11:09 PM
99blackcivicSi's Avatar
Default Re: Two vtec engagements in less than a second? (VtecDA9)
what kind of head are you running? GSR? stock mani? are the Butterflys taken out?
Old Dec 5, 2003 | 11:38 PM
VtecDA9's Avatar
Default Re: Two vtec engagements in less than a second? (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">what kind of head are you running? GSR? stock mani? are the Butterflys taken out? </TD></TR></TABLE>
Running b16 head w/ ITR IM
Old Dec 6, 2003 | 12:08 AM
mmuller's Avatar
Mad Scientist
if vtec is hesitating, then your sol. might be going bad. how's your oil level/pressure?
Old Dec 6, 2003 | 09:56 AM
Kendall's Avatar
I agree, the solenoid sounds like the culprit and the primary reason for their failure is lack of oil pressure.
Old Dec 6, 2003 | 11:14 AM
VtecDA9's Avatar
Default Re: Two vtec engagements in less than a second? (mmuller)
[QUOTE=mmuller]if vtec is hesitating, then your sol. might be going bad. how's your oil level/pressure?[/QUO
Oil is always a lil past the second mark. Vtec always engages, it's just that sometimes it hesitates. The silinoid is leaking, could that affect it? I tried to seal it with copper seal and it still leaks.
I'm screwd as far as taking the silinoid off to reseal because I over torqued a bolt and snapped it.
Old Dec 6, 2003 | 05:42 PM
myhatchrips's Avatar
mine does the same thing. im thinking its because i have a huge dip in my powerband just before vtec.
Old Dec 6, 2003 | 06:29 PM
bogus_ek's Avatar
Default Re: Two vtec engagements in less than a second? (myhatchrips)
that might be too early of a vtec engagement point. get a vtec controller, and try setting it a little later like at 5000 or 5500.
Old Dec 6, 2003 | 07:13 PM
Default Re: Two vtec engagements in less than a second? (bogus)
its at 5700 rpm
JSpekBB4
Oct 30, 2007 10:23 PM
theEGkid
Apr 20, 2005 07:56 AM
mrbsponge
Sep 25, 2004 04:42 AM
Nsane1
Jun 12, 2004 04:47 PM
