TWM short shifter write up
Old Aug 31, 2003 | 10:27 AM
  #26
Quik Chris's Avatar
Default Re: TWM short shifter write up (exospeedAMcrx)
Fun to drive, except when you shift from 1st to 2nd at redlines and it grins everytime unless you wait for the RPM to drop to 5700. Same with the 2-3 shift.
I don't see the fun in burning gears up.....
Old Aug 31, 2003 | 11:03 AM
  #27
zman300's Avatar
Default Re: TWM short shifter write up (Quik Chris)
ok i drive a nissan 300zx and my tranny grinds from 3-4. (common in all z's) the thing that is probably grinding are your synchros... what fixed it (atleast made it a lot better and not as often) was putting in a thicker transmission fluid. Redline Transmission fluid is the best that i have experienced. the problem is that the synchros are soo light and with a highly lubricated fluid they often slip when matchin up the rpm's with the gear.... hope this helps!
Old Sep 2, 2003 | 08:19 AM
  #28
Quik Chris's Avatar
Default Re: TWM short shifter write up (zman300)
No bro, this is because the shifter is trying to shift gears too fast and the syncros can't keep up, my tranny wasn't bad in the first place.
Boostn B20
Jul 12, 2011 07:35 PM
JDean6pac
Feb 21, 2006 10:38 AM
jaspie
Aug 15, 2005 12:27 AM
tdog
Feb 11, 2002 06:35 PM
