Trunk release on Del Sol
Old Apr 26, 2011 | 03:51 AM
pluckedchicken's Avatar
Default Trunk release on Del Sol
When operating the interior trunk release, or opening the trunk with the key from outside, the trunk lid does not "pop" open. both release and key unlock the trunk but you must manually lift the lid.
kind od a pain to put down what ever is in your hands so one hand can turn the key while the other hand lifts the lid, or using the interior release have someone waiting at the rear to lift the lid as you hold the release up
Is this the way it was designed? is there a way to make it "pop" open?
Old Apr 26, 2011 | 07:04 AM
mik101's Avatar
Default Re: Trunk release on Del Sol
No its not supposed to pop all the way up but you need to clean your trunk latch.
You will still obviously have to lift the trunk, but you should be able to pull the handle inside or turn the key (and remove the key) THEN lift the trunk lid. It sounds to me like you're having to pull it open while holding the lock?
You may need to take the plastics around the back of the trunk off to do it properly.
My winter beater just did the same thing, except when it stuck it wouldn't let the trunk close again either.
Old Apr 26, 2011 | 07:16 AM
Yep, I have to hold the key turned and lift the lid at the same time. Just turning and removing the key leaves it locked. Same way with the interior release, as long as it's held up the lid will open, if you let it go the trunk remains locked.
I'll give it a good cleaning and see how it goes
Old Apr 26, 2011 | 01:28 PM
blackedEk's Avatar
latch needs cleaning
check spring in latch
check cable
or just order new latch
Old Sep 12, 2011 | 10:40 AM
Kentour69's Avatar
Ha ha I found this to be pain as well...I just installed some springs just under the trunk that way when I open the trunk it will POP open.
Mylinh
May 31, 2011 03:09 PM
craven160
Apr 7, 2011 12:41 PM
yunebug
Jun 27, 2010 02:24 PM
saltybeagle
Apr 13, 2010 11:46 PM
darkwolf_777
11
Jun 29, 2004 12:30 AM
