Troubleshooting: VTEC Crossover-engagement issue
Old Mar 6, 2018 | 06:37 PM
Em1Dustin's Avatar
Icon4 Troubleshooting: VTEC Crossover-engagement issue
ok so I have a lsvtec build in my si everything is plugged up correctly speedometer works even though it reads about 15 mph difference from waze app also oil is at the correct level what else could cause it too not work I have a chipped p28 and I have a stock si Ecuador I plugged up still not need help
Old Mar 12, 2018 | 10:18 AM
TheShodan's Avatar
Moderator
Default re: Troubleshooting: VTEC Crossover-engagement issue
Check the FAQs and check to see if the actual solenoid is operating. VTEC engagement is both a ECU and physical engagement via an oil pressure solenoid and an electrical input to that solenoid via the ECU.
Old Mar 13, 2018 | 09:23 PM
Em1Dustin's Avatar
how will I know if the solenoid works or not... I guess my question is how can I test it
Old Mar 13, 2018 | 10:05 PM
holmesnmanny's Avatar
you apply battery voltage to the solenoid, listen for it to click
Old Mar 16, 2018 | 02:16 PM
Em1Dustin's Avatar
Default Re: Troubleshooting: VTEC Crossover-engagement issue
where do I hook it up too
Old Mar 16, 2018 | 05:57 PM
Old Mar 17, 2018 | 04:45 PM
Em1Dustin's Avatar
like do I hook it up to the single wire or dual wires
b16turbointeg
11
Apr 7, 2009 06:00 AM
JDM91EF2
Oct 12, 2006 02:38 PM
Layziejoe775
Feb 5, 2006 11:33 AM
boosted k20
Jul 21, 2005 07:15 PM
acdracing
Dec 13, 2004 06:13 PM
