Troubleshooting: F22a1 Won’t Start and stay running without WOT.
Ok so maybe y'all can help. Got the head back on compression test was 155/145/155/170. I am going to readjust the valves again and see if I can get those numbers a little closer together.
I attempted to start it the other day and it would not start unless I was WOT and had it crank for a good couple cranks. Now I don't know if this is due to the basemap or what. I have my wideband hooked up and the gauge was reading around 16.8 when I was WOT or holding it at 2k.
I decided to pull the plugs and see if I can see anything and this is what I found:
Its kind of hard to tell but 1 &4 are covered in soot and 2&3 are blackish with a gloss to them. I decided to check the injectors first thinking maybe they were spraying and I found the resistance to all of them were .007 and that they were all seeing 12 volts. Only thing I didn't check was the signal wire, but that is due to not having someone available to crank while I check.
I think the injectors and harness are fine as I used this same harness on the h22, along with the fuel lines and fuel pump. So my questions are:
what could be causing the need to be WOT to get it start and stay alive?
Why are 1&4 spark plugs full of carbon and 2&3 aren't?
So the only variables I have changed between the h22 and this motor are, the motor, the turbo, the dizzy(though I swapped the h22 dizzy guts into the f22 body), intake manifold but not throttle body, map sensor, injectors.
Pretty much everything else is the same from the h22. I know the map sensor is reading correctly because we saw it when Blake hooked up his laptop, and he calibrated the tps while getting ready for the first start up.
Could these issues be from the basemap not being complete? Or is there something else going on? I am lost here guys....
Here is my laundry list oh what’s been done to the engine:
F22a1Block
85.5mm Wiesco pistons
Bisimoto h-beam Piston Rods
ARP Head Studs
ARP Rod Bolts
KS Balance Shaft Eliminator Kit
Rebuilt OEM Oil Pump
OEM Bearing
Micropolish Crankshaft
CYLINDER HEAD:
F22a1 SOHC
Delta Cam 272 regrind
AEM Tru-Timing Gear
OEM valves
SuperTech Valve Seals
Bisimoto Pro Series Springs and Stock Retainers
OEM Timing Belt
PnP/ Port Match Plenum JDM F22b Intake manifold
Omnipower 70mm Throttle body
Omnipower 4bar map sensor.
TURBO SET UP:
850Fab Custom Ramhorn SS manifold
Borg Warner s200xe-57
Tial 38mm wastegate
Tial 50mm BOV
Treadstone Intercooler Piping Kit
Greddy Front Mount Intercooler
3" Mandrel bent exhaust
Vibrant Ultra Quiet Resonator
Megan racing muffler
MAC Boost Solenoid
FUEL SYSTEM:
Injector Dynamics 1050cc injectors
Walboro 255lph fuel pump
GM Flex Fuel Sensor
Marshall fuel pressure gauge
MISC:
DIY short shifter
Competition Clutch Stage 4 6 Puck Sprung clutch
JDM T2W4 Transmission
Civic aluminum half-radiator
P06 with Hondata s300 V3
Battery relocated to the Trunk
KMS EGR Block Off Plate
Wire tuck
DIY Poly Filled motor mounts
ShaySpec solid bushing for shifter linkage
Shayspec Solid bushing for shifter assembly.
MTEC H22 Shift Springs
F22a1Block
ARP Head Studs
ARP Rod Bolts
OEM Bearing
CYLINDER HEAD:
F22a1 SOHC
AEM Tru-Timing Gear
OEM valves
OEM Timing Belt
TURBO SET UP:
Tial 38mm wastegate
Tial 50mm BOV
MAC Boost Solenoid
FUEL SYSTEM:
GM Flex Fuel Sensor
MISC:
DIY short shifter
Wire tuck
