1998 Honda Oddssey door lock wiring ground points
Hi,
I am hoping to find a wiring diagram for this model. I am looking for ground points G 410, 402, 403 as they relate to driver's power door lock operation. Car has key-less entry, however I will be talking about opening the doors by putting the key physically into the door lock cylinders.
The problem is that the key in the drivers door lock will lock ONLY the drivers door, and the interior drivers door lock switch does NOT work. The key in the pass door will lock ALL doors, and pushing the pass door interior lock switch will lock ALL doors.
The drivers door key cylinder switch, and the drivers door interior power door lock switch both test good with ohm meter, per workshop manual test procedure.
I am trying to find ground points G 410, 402, 403 to test them, per workshop manual.
