transmission tech question
Old Jan 11, 2002 | 05:32 PM
supergreenNA1's Avatar
New User
Default transmission tech question
are gears compatible between trannys?
the reason i ask is because i have always liked the smooth dual synchro shifting of the gsr tranny.. but prefer the longer gears of the ls. so i would like to build up a gsr tranny with ls gears if that is possible.
anyone have experience with this?
Old Jan 11, 2002 | 06:41 PM
court's Avatar
25 Year Member
Default Re: transmission tech question (supergreenSol)
there are only subtle differences between the two transmissions of the 94-01 y80's( gsr/ ls/gs)
gears, and final drive( diff bearings too). idont know what you mean by dual synchro shifting.
however, a comon hybrid trans is a gsr final with the ls gears. this is comonly used with b sereis turbo motors on the strip.
Old Jan 11, 2002 | 09:41 PM
rainforest's Avatar
Default Re: transmission tech question (court)
yes they are compatable and fun to install.
Old Jan 12, 2002 | 03:24 PM
IN VTEC's Avatar
The gear spacing on the GS-R is better. If you wanna help the turbo out then use the LS's final drive to give the turbo more time to spool.
Boostage
Nov 14, 2011 03:50 AM
Hoppa
May 7, 2006 01:47 PM
Rain n Blood
Aug 18, 2004 04:51 PM
jdm_gsr
Feb 11, 2004 05:55 AM
lambgsr1
Jan 16, 2003 05:14 PM
