transmission problems
Old Jun 19, 2007 | 11:59 AM
itsLOUiSduh's Avatar
Default transmission problems
i juss put a new D series tranny in. for the first month it was good. now whenever i take off in first gear or reverse, the whole car shakes like its wheel hopping. does anybody know whats wrong? i already popped a hole in my axle boot n broke a exhaust hinge because of it
Old Jun 19, 2007 | 05:28 PM
Default Re: transmission problems (itsLOUiSduh)
bump
Old Jun 19, 2007 | 07:57 PM
i_drive_a_honda's Avatar
i have heard it can do this if you get have air in the slave cylinder line, try bleeding it.
Old Jun 20, 2007 | 01:56 PM
King V's Avatar
Could be real bad clutch chatter. Or a busted/misaligned axle.
Old Jun 20, 2007 | 02:45 PM
sirtef9's Avatar
Default Re: transmission problems (200kCivicSI)
wouldnt that do it in all gears? the first and reverse are the same gear, so my guess is something inside the trans
Old Jun 20, 2007 | 04:22 PM
Default Re: transmission problems (sirtef9)
its a 6 puck clutch. my axles is brand new also. i dont think it could be the gears because in first and reverse its really bad but sometimes when i shift it shakes a little bit. i heard from 2 people it could be because i didnt resurface my flywheel.
Old Jun 21, 2007 | 11:59 AM
bump
Old Jun 22, 2007 | 12:50 AM
92_VX_EG's Avatar
You don't really have to resurface your flywheel when using a 6 puck. They do it for you. It seems as though your clutch is dragging or you're not giving it enough gas when taking off in 1st or reverse. Just ride the clutch and break it in a little more and you should be fine. I have a 6 puck in mine and I didn't resurface the flywheel... it did the same thing until I broke it in.
Old Jun 22, 2007 | 11:16 AM
Bense's Avatar
i think it's something in the clutch/pressure plate area
CarBug
Jun 9, 2016 02:58 PM
turbocivic0618
Oct 10, 2005 10:53 AM
Ministry
Oct 18, 2004 09:38 AM
ITR21
May 19, 2003 02:22 PM
