transmission housing
Old Oct 18, 2003 | 08:12 AM
eyesonlybob's Avatar
Default transmission housing
over the weekend i replaced my 1st/2nd syncro set. all went well, but now im trying to get the tranny housing back on, and somethings not lining up.
the gap between the tranny housing and the clutch housing is the same all the way around, but i cant get it down any further. the snap ring on the counter shaft isnt close enough, so thats not the problem. i think it is the top of the shift forks. where they go into the housing. anyone done this? suggestions?
Old Oct 18, 2003 | 08:28 AM
pro1342's Avatar
Try putting it in second gear......it should fall.
Old Oct 18, 2003 | 08:43 AM
how do i put it in second gear with the trans out?
Old Oct 18, 2003 | 08:55 AM
pro1342's Avatar
Stick a screwdriver or something in the hole on the shaft, turn it left, and pull.
Old Oct 18, 2003 | 09:28 AM
it worked, thanks a lot
Old Oct 18, 2003 | 11:38 AM
pro1342's Avatar
No problem.
Old Oct 18, 2003 | 12:13 PM
Mochanic's Avatar
Default Re: (pro1342)
did you make sure to line up the tab for the reverse synchro into the tranny case? And make sure the tabs faces down toward the bell housing?
ricky tan
Oct 5, 2012 07:57 AM
DC_RaceR
Oct 8, 2006 04:16 PM
sloaccord
Mar 23, 2005 10:31 PM
boomslang
Nov 2, 2001 06:21 AM
boomslang
Oct 30, 2001 08:29 PM
