Okay, I am desperate, tranny problem, please help.
Man, I just spent the last hour trying to get my tranny housing back together. The tranny housing will lower until it is about 1/2 of an inch all the way around and won't go down any farther. All the shift forks are lined up. The pins in the housings aren't touching yet so I know it isn't them causing it to not go together. What the heck is going on? I can't figure it out.
The clip on the top of the mainshaft is aligned properly too.
I just spent another 1/2 hour on it, it just won't go together!
Re: Okay, I am desperate, tranny problem, please help. (Inlinefour)
are you spreading the c clip apart on top of the shaft and picking up on the bearing
try to wiggle the shifting shafts with a screwdriver/ this sometimes helps
is this trans a (d series)(b series)(prelude-accord)
crexer
10-10-2004 04:15 PM
