Transmission grinding, which is which
Old Oct 10, 2005 | 08:24 PM
n-line4's Avatar
Default Transmission grinding, which is which
is this correct?:
If you grind going from:
1st to 2nd = 1-2 synchro set worn
2nd to 3rd = 3-4 synchro set worn
3rd to 4th = 3-4 synchro set worn
4th to 5th = 5-R synchro set worn
Reverse grinds = 5-R synchro set worn
into 1st grinds = 1-2 synchro set worn
if anything is wrong, correct me please
Old Oct 11, 2005 | 03:34 AM
JimBlake's Avatar
Default Re: Transmission grinding, which is which (n-line4)
Reverse isn't synchronized.
Grinds going into 1 = 1st gear synchro is worn.
Grinds going into 2 = 2st gear synchro is worn.
Grinds going into 3 = 3st gear synchro is worn.
Grinds going into 4 = 4st gear synchro is worn.
Grinds going into 5 = 5st gear synchro is worn.
That's pretty simple, but...
1st & 2nd gear synchros are built together on a shared hub.
3rd & 4th are on a shared hub.
TomCat39
Transmission & Drivetrain
Oct 11, 2016 02:26 PM
K&BRacing
Nov 13, 2010 02:19 PM
Destructive-
Jan 29, 2008 08:55 PM
skribblah
Sep 8, 2003 01:34 PM
