Transmission flush or not?
Old Sep 21, 2004 | 06:37 AM
delsol93guy's Avatar
Default Radiator flush or not?
I bought my b18c and the previous owner was using gm dexcool crapt and i was wondering i should do a radiator flush or not and if anyone knows what could happen to my motor is i use that anti-freeze for to long?! Please help i need to know!
Thanks in advance!
Josh R.
Modified by delsol93guy at 10:09 AM 9/21/2004
Old Sep 21, 2004 | 07:02 AM
Big Teggie's Avatar
Default Re: Transmission flush or not? (delsol93guy)
Switch it out asap. Any kind of antifreeze is no good to use in a transmission.
Get some Honda manual transmission fluid and yoube fine.
Old Sep 21, 2004 | 09:08 AM
Default Re: Transmission flush or not? (Big Teggie)
im sorry i meant an engine coolant flush or whatever.. like i need to flush the radiatior or whatever it is called!
thanks for the help though
Old Sep 21, 2004 | 09:29 AM
JimBlake's Avatar
The corrosion package in DexCool (carboxylic acids) doesn't play nicely with almost any other. Best to rinse it out completely.
Take off a radiator hose (or both), see whether you can see inside. Any crud or crusty build-up in there? If it's cruddy, use some kinda chemical flush. If not, you can probably just rinse the daylights out of it.
Take out the thermostat. Run a garden hose into the lower hose leading towards the engine, let it pour out thru the upper radiator hose. Have the heater control set to full-hot so it goes thru there, too. Then run water thru the radiator.
Then I'd fill/drain with distilled water a couple times. THEN put the new antifreeze in.
cabdolla
Mar 14, 2012 12:22 PM
ree21
Mar 14, 2008 10:37 AM
f0shizzy619
Apr 19, 2005 12:36 PM
Specialk
May 22, 2003 08:59 AM
mcchen
Jan 13, 2003 10:45 PM
