how to replace coolant
Old Jan 13, 2003 | 08:53 PM
mcchen's Avatar
Default how to replace coolant
Just bought a 97 GSR, I want to change engine coolant, but i don't know where is the drain bolt and washer from the engine block. Anyone gets pics for it or any help will be appreciated.
Old Jan 13, 2003 | 09:04 PM
lucas569's Avatar
Default Re: how to replace coolant (mcchen)
its real simple actually, just lift the car (use stands btw) and look under by the radiator youll see a hole, reach under there and twist the wing nut thats on the bottom of the radiator.
place old rad fluid in the proper container,etc...
get some rad flush fluid and follow instructions on the bottle,wait till the fan kicks on (let cool) then drop that stuff as well. now you can put the new rad fluid in (i use the honda fluid btw cause it lubricates the water pump well, but you can use most any)
refill w/ the new rad fluid and bleed it at the bleed bolt by the head/upper rad hose, be careful not to snap that little thing cause it is easy to do.
make sure theres no bubbles and your good to go.
Old Jan 13, 2003 | 09:05 PM
nfn15037's Avatar
Buy a helms manual, itll be your best investment in your car http://www.helminc.com
Old Jan 13, 2003 | 09:27 PM
mcchen's Avatar
Default Re: how to replace coolant (lucas569)
Thks for your time, i did found the drain plug on the bottom of the radiator, how about the drain bolt from the engine block, it seems different things mentioned on the menu.
Old Jan 13, 2003 | 09:42 PM
GSRaCeRbOI's Avatar
yes go buy a helms manual.. it'll start paying for itself when you start saving money doing maintenances and repairs yourself...
in the meantime check out this link for your coolant question:
http://www.bseries.net/html/garage/thermo.php
Old Jan 13, 2003 | 10:45 PM
mcchen's Avatar
Default Re: how to replace coolant (GSRaCeRbOI)
cool, it's helpful!! thanks
Prudz_lude
May 1, 2007 12:27 PM
CRISIS
Jan 6, 2007 10:45 AM
mrx
Jun 18, 2006 10:21 AM
Knight1
Mar 21, 2006 12:24 AM
f0shizzy619
Apr 19, 2005 12:36 PM
