Transmission assembly problem
Old Mar 8, 2004 | 09:42 AM
sorrule's Avatar
Default Transmission assembly problem
Eh yo, I got a problem here.... this weekend I was changing my clutch and now I'm having trouble bringing the transmission back up to the engine and aligning the teeth right for it to fit in to the clutch. Does anyone have a special technigue or way to help get it in easier. All I have are three jacks and a couple friends helping me do this... ghetto as hell huh, but that's all I have to work with.. thanks
Old Mar 8, 2004 | 09:47 AM
RedlinedVTEC's Avatar
Default Re: Transmission assembly problem (sorrule)
Ahh yeah it sometimes can be little tricky lining up the input shaft, try putting some grease on the end of the shaft and "jiggling" the tranny in should do the trick.
Old Mar 8, 2004 | 10:19 AM
AL ASPIRATED's Avatar
try to eyeball the splines of the clutch disc and the pilot bearing. make sure its looks straight. if u used one of the dummie shafts to line up ur disc, then its prob not straight. thoese suck.
also try a little grease, VERY little on the pilot bearing
Old Mar 8, 2004 | 11:24 AM
BauleyCivic's Avatar
Risky Business
Default Re: (AL ASPIRATED)
keep jacks under both the engine and tranny...and align them so that they are at the same height, then just slide it in
Old Mar 10, 2004 | 11:55 PM
trialoner's Avatar
I like to put a little grease on my shaft and jiggle it, also. I guess I shouldn't make fun, I am putting a b16 tranny on a b18 engine next week...
Old Mar 11, 2004 | 06:06 AM
sorrule's Avatar
Default Re: Transmission assembly problem (trialoner)
have fun tryin to align that shizz, it's gonna be a bitch.. good luck to you, unless you have a hoist then good thinkin
Old Mar 11, 2004 | 07:19 PM
crxhybrid1320's Avatar
I always make sure the splines on the clutch dics are the same as the tranny. One time I got the wrong splined clutch. I know the 90-91 and 92-up b-series clutch discs are different. Also one time one of the splines was not perfect and had a bur on the end and was hard to slide on at first. Make sure its the right clutch disc, lube it up, and good luck. They can be a real pain sometimes depending on car make and mode, especially a prelude sh with separate LSD unit.
JAson
lolv8s
K Series
Aug 23, 2015 12:50 PM
.adam.
Oct 30, 2009 07:58 PM
JdmFront619
Oct 28, 2003 12:25 PM
el arbi
Apr 18, 2003 08:21 AM
