Miss fire in all cylinders
Old Mar 9, 2004 | 09:45 AM
DocV's Avatar
Default Miss fire in all cylinders
hey what's up guys. I'm looking for some help. I have a 01 Gs-R w/ a b18c5 bottom end, b18c1 head, PnP, Ctr cams, itr valves, portflow valve, springs and a 01 itr ECU. I have a very rough idle and it fluxuates(sp) up to 1,100 and down to 300. also i have a check engine light and reads mis fires in all cylinders and i dunno if i have ne others b/c my friends honda scanner can only do 4 codes at a time. I was talking to guy who PnP my head and said maybe my map or iacv could be bad. i'll take suggest from here
Old Mar 9, 2004 | 09:54 AM
RedlinedVTEC's Avatar
Default Re: Miss fire in all cylinders (VtecNit2k1)
Check ignition issues? Cap and rotor ok? You getting solid spark on all cylinders? How do your plugs look? Start there.
Old Mar 9, 2004 | 01:06 PM
doublejz's Avatar
Default Re: Miss fire in all cylinders (RedlinedVTEC)
the rough/fluctuating idle is probably: map, tps, or vacuum. My first guess would be tps. Just for curiousity unplug your tps when the car is fluctuating and see if it idles normal.
Old Mar 9, 2004 | 03:47 PM
DocV's Avatar
Default Re: Miss fire in all cylinders (doublejz)
def not cap, rotor, wires ,and plugs they are all brand new. Ok i pulled the iac while it was running and it bog down but still didnt' run normal. Prob the map sensor?
Old Mar 9, 2004 | 04:06 PM
doublejz's Avatar
not the iac pull the tps
Old Mar 11, 2004 | 07:07 PM
DocV's Avatar
what should happenif i pulled the tps out?
Old Mar 11, 2004 | 07:23 PM
doublejz's Avatar
the idle should quit bouncing up and down. that is if the tps is your problem
Llovero95
Jan 31, 2016 06:31 PM
big_jule
23
Sep 19, 2012 04:11 PM
evil em1
Jun 22, 2006 04:21 PM
VTECth1s
May 31, 2006 05:26 AM
frostt3ch
13
Apr 2, 2006 05:41 PM
