Trans fluid in Ford Ranger
Old Dec 11, 2003 | 10:24 AM
Philip's Avatar
Default Trans fluid in Ford Ranger
This forum is better than all others, so I'm asking this question here.
I know it's a long shot...
Does anyone know what would be a good trans fluid for my 2000 Ford Ranger? It's very hard to shift.
I know my civic began shifting like butter when I went from synthetic oil to Honda MTF.
Right now the Ranger has the same fluid it came with from factory. Thanks!
Oh it's the 3.0L V6 Engine, with manual tranny.
Old Dec 11, 2003 | 01:25 PM
Philip's Avatar
Default Re: Trans fluid in Ford Ranger (Philip)
anyone?
Old Dec 12, 2003 | 04:38 AM
JimBlake's Avatar
Does the owner's manual say anything about an oil specification? Like API GL4 or something? Lately there's some transmissions that only want some proprietary stuff.
Old Dec 12, 2003 | 04:41 PM
PupaScoopa's Avatar
Default Re: Trans fluid in Ford Ranger (JimBlake)
I was about to recommend some GM Synchromesh... yet I remember an old truck I had used heavy GL5 gear oil. That stuff would kill Honda bearings in a hurry though... and GM Synchromesh may be too thin for that transmission. Check w/the dealer!
Old Dec 13, 2003 | 12:18 PM
Philip's Avatar
Default Re: Trans fluid in Ford Ranger (PupaScoopa)
Thanks guys. It takes some kind of Mercon ATF. The only thing I can find is that some people have used synthetic ATF. I didn't even think about calling the dealer. Thanks again.
Old Dec 13, 2003 | 01:52 PM
Jim Truett's Avatar
If your manual trans takes Mercon ATF, GM Synchromesh is compatible.
Old Dec 14, 2003 | 06:08 AM
Regular Series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote">I know my civic began shifting like butter when I went from synthetic oil to Honda MTF.</TD></TR></TABLE>
Just wondering - were you using Redline MTL? I have that in my 98 Teg, and the shifter can be pretty grouchy...
RS, who likes his syncros in one piece.
Old Dec 16, 2003 | 08:47 AM
Philip's Avatar
Default Re: Trans fluid in Ford Ranger (Regular Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Regular Series &raquo;</TD></TR><TR><TD CLASS="quote">
RS, who likes his syncros in one piece. </TD></TR></TABLE>
no, Mobil 1, i heard that Redline makes shift even smoother than Honda MTF. I'll stick to Honda though.
Old Dec 16, 2003 | 01:31 PM
I dunno, my shifts are still pretty rocky. I really can't shift very quickly at all. Apparently my linkage is wonky, or I really suck at shifting...
Old Dec 29, 2003 | 06:19 PM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. It takes some kind of Mercon ATF. The only thing I can find is that some people have used synthetic ATF. I didn't even think about calling the dealer. Thanks again.</TD></TR></TABLE>
ide say use the stock stuff.
the only reason i think it would be rocky is because its old, and used. try it, it shouldnt be that expensive. and if you dont like it then ide recommend sum synthetic stuff.
good luck.
jonnybadboi9
Jun 10, 2016 02:56 PM
313hitman
Mar 20, 2009 06:50 PM
NZDelsoldude
Sep 23, 2004 02:44 PM
SystemGSR
Nov 14, 2002 06:58 AM
Rah Rah
Dec 25, 2001 03:18 PM
