tranny rebuild ?.... replace only syncros? or full gearset?
i searched tons but didnt come up with anything i was looking for
my tranny has got 102k on it and its starting to grind 2nd pretty regularly so i want to go ahead and redo it before it gets too too bad........ i want to replace all the bearings while i have it apart i just dont know if its neccessary to replace the entire gearsets or just replacing synros will be ok? if its ok i wanna get some gearspeed syncros so it will cut costs alot
what about the gear sleeves? should they be replaced or will they be ok too?
thanks for any help given
u will know better once you pull tranny apart def check syncros id change anyway but also check your hub and slider those usuall round off and cause shifting probs
i guess i just better go ahead and buy everything cus its my daily so im trying to have all the parts needed so it will only be down for a weekend.... wont have any way to get around without it
edunnett
Oct 1, 2004 06:06 PM
