tranny between d16z6 and d16y8???
Old Oct 17, 2003 | 11:45 PM
jdmCivic925's Avatar
Default tranny between d16z6 and d16y8???
whats the different between d16z6 tranny and d16y8 tranny....is it the gear ratio???
Old Oct 18, 2003 | 12:34 AM
Don Napier's Avatar
Import Alliance
Default Re: tranny between d16z6 and d16y8??? (delsol925)
some guy in my home town swears that his d16y8 tranny has a stock l.s.d. Could this be true?
Old Oct 18, 2003 | 07:41 AM
MIRRAdekhtc's Avatar
Default Re: tranny between d16z6 and d16y8??? (suprfast)
he is right....he's full of poop....maybe aftermarket, KAZZ, or Quaife, but not factory, gearing is identical.
Old Oct 19, 2003 | 10:47 AM
Old Oct 19, 2003 | 10:56 AM
d15nonvtec's Avatar
Default Re: (delsol925)
i believe the y8 is a shade beefier, same ratio, just a tad stronger
Old Oct 19, 2003 | 12:02 PM
okay thanks bro...
Old Oct 19, 2003 | 12:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol925 &raquo;</TD></TR><TR><TD CLASS="quote">whats the different between d16z6 tranny and d16y8 tranny....is it the gear ratio???</TD></TR></TABLE>
The biggest difference I can think of is the z6 has aluminum shift forks instead of steel. I think the y8 shift a little better for this reason.
Old Oct 19, 2003 | 01:38 PM
PHiZ's Avatar
Default Re: tranny between d16z6 and d16y8??? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
The biggest difference I can think of is the z6 has aluminum shift forks instead of steel. I think the y8 shift a little better for this reason.</TD></TR></TABLE>
-PHiZ
Old Oct 19, 2003 | 06:13 PM
kommon_sense's Avatar
Default Re: tranny between d16z6 and d16y8??? (PHiZ)
as others have said, z6 and y8 are the same. only diff is y8 has steel shifter forks instead of aluminum, so y8 is a little sturdier.
Old Oct 20, 2003 | 11:14 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: tranny between d16z6 and d16y8??? (kommon_sense)
Z6 2nd gear = 1.900
Y8 2nd gear = 1.909
that is NOT a typo!
Old Oct 21, 2003 | 03:28 AM
Chiovnidca's Avatar
Default Re: tranny between d16z6 and d16y8??? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Z6 2nd gear = 1.900
Y8 2nd gear = 1.909
that is NOT a typo!</TD></TR></TABLE>
Are you sure?
Old Oct 21, 2003 | 12:22 PM
Mista Bone's Avatar
D Tranny Guru
I split down a Y8 case just to be sure. I figured it was a typo in the factory service manual.
muhaMan
Jun 3, 2007 11:08 PM
VvPeachyvV
Jun 24, 2004 10:44 AM
REDGEAR
Jun 17, 2004 05:20 PM
2camsaam
May 25, 2004 08:10 AM
Eziekel
10
Dec 26, 2003 05:00 PM
