D17 tranny to D16Y8
D17 tranny to D16Y8
Is this possible?
Also, what is the advantage of this tranny over Z6 or Y8 if this is possible?
Thanks!
Modified by REDGEAR at 11:44 PM 6/13/2004
Thanks!
Re: D17 tranny to D16Y8 (REDGEAR)
they are the exact same tranny minus gearing, easy mod for what you gain. you will love it, i will never run anything but a vtec tranny on sohc
did you mean D16 tranny in your title?
well the difference between the two, are the shift forks.
D16Z6 transmission uses aluminum shift forks (weaker).
D16Y8 transmission uses steel shift forks (stronger).
which makes the Y8 the better between the two. the gear ratios are practically identical.
the Y8 is the best D-series tranny.
Re: D17 tranny to D16Y8 (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">did you mean D16 tranny in your title?
the Y8 is the best D-series tranny.</TD></TR></TABLE>
he meant D17, the new EX's have D17's.
Re: D17 tranny to D16Y8 (Mar_EK)
you need to keep what ever rear tranny mount that came out of the car, y8 tranny mount wont work in a 92-95 civic, and vise versa
TravisCadello
36
04-25-2009 07:41 PM
