TPS Throttle Position Sensor Grounding
Old May 22, 2006 | 02:52 PM
upstatee's Avatar
Default TPS Throttle Position Sensor Grounding
Hey everyone, ive been throwing alot of tps sensor codes for too low of a voltage and checked over the wires with a voltmeter and the wire that is supposed to be grounded, the green (which is all the way to the right on the connector if your looking at it) has voltage, has anyone else run into this? could i just ground it elsewhere or does it share a ground with something?
csunny95
Sep 20, 2018 10:15 AM
dohc_profile
Nov 27, 2006 07:26 AM
ScottEK
Jun 12, 2006 06:02 AM
all_motor
Feb 14, 2005 09:52 PM
Morhpeous
May 24, 2004 07:00 PM
