TPS sensor removal??
Old Sep 25, 2002 | 07:18 PM
flat-blk-HB's Avatar
Default TPS sensor removal??
What is the best way to remove this thing? I will be doing my swap soon, and while carring my engine home in my car it tipped forwared and broke that damn thing clean in half But I was just wondering since it is pop rivited on and all. Thanks..
Old Sep 25, 2002 | 07:27 PM
paulzy's Avatar
Default Re: TPS sensor removal?? (!)
drill them out...you have to adjust the new one too
Old Sep 25, 2002 | 07:31 PM
poison's Avatar
just take off the whole throttle body when doing it.
edit -> nevermind, didn't see that you broke it
when you get a new one, take the whole throttle body off when installing it, that way you don't break it again
[Modified by poison, 9:32 PM 9/25/2002]
Old Sep 25, 2002 | 08:35 PM
Default Re: TPS sensor removal?? (poison)
Thanks for the help..But some people said you can cut notches in to the rivet style things and screw them out with a flat head screw driver... Hopefully this is true.
Old Sep 25, 2002 | 08:38 PM
Jockobo's Avatar
i just used a hammer with a flat head and unscrewed it by hitting it till it screwed out.
Old Sep 25, 2002 | 08:42 PM
Default Re: TPS sensor removal?? (Jockobo)
Thats cool...
Hey man whats up? I am the one that had that 89 CAMO DX Hb with the LS from Kennadale..The one with slicks..
Well I traded that car for a 92 DX and I am putting a D16Y8 in it soon..Just need a ECU..You got any parts for a SOHC VTEC?
Old Sep 25, 2002 | 08:47 PM
kinesistech's Avatar
Cutting slots is the best way. You can reuse them if you wish or use new bolts once they're out. If you have or know anyone with a vafc (or safc), plug your TB to the car that has it and use it to calibrate the TPS. Closed is .45v and WOT is 4.5v. Thats the easist way I know to do it, it takes 15 seconds.
Old Sep 25, 2002 | 09:00 PM
Default Re: TPS sensor removal?? (kinesistech)
IS there anyway to mark it or anything?
Old Sep 25, 2002 | 09:08 PM
Use your dremel tool and make a scribe on the TB and TPS in the same spot. Why are you removing it?
Old Sep 26, 2002 | 03:33 AM
Jeff C's Avatar
whats the harder way to do it if an afc is not avaliable?
does auto zone or napa sell the tps...separately?
mindless head
May 31, 2015 07:38 PM
TASAuto.com
Performance
Jul 19, 2009 05:35 PM
cazper8890
Mar 2, 2007 08:25 PM
dohcMONSTER
15
Jul 5, 2004 06:26 PM
SIcivic10
Sep 29, 2002 05:33 PM
