TPS sensor removal
Old Jan 12, 2006 | 05:57 AM
JUN_H22A's Avatar
Default TPS sensor removal
Just bought a AN-R 70mm TB and I feel retarded but I can't seem to figure out how to remove the TPS sensor unit off the oem TB. it looks to be studed on the TB? anyway I was about to drill it out but decided to ask on here first. Thanks
btw: this is for a H22 TB if it matters
-Jeremy
Old Jan 12, 2006 | 08:42 AM
mstolars's Avatar
Default Re: TPS sensor removal (JUN_H22A)
If you didn't find the answer yet through a search, all you need to do is get a dremel and make a slot into the center of those screws that are holding the tps in place. Then just take a flat head screwdriver and unscrew the screws. There have been other ways to get them out, but this is the way I've always done it. Hope this helps
Old Jan 12, 2006 | 09:25 AM
drdisco69's Avatar
Default Re: TPS sensor removal (mstolars)
Or if you can get pliers on the little stubs, all it takes is like 1/8th of a turn and you can back them out with your fingies.
polything
23
Jul 27, 2012 08:23 AM
Luserkid
Dec 9, 2004 02:24 PM
hybrid_crx
Nov 23, 2004 01:19 PM
killa_lude
Dec 26, 2003 04:52 PM
rasta420
17
Apr 11, 2003 02:24 PM
