TORQUE SPECS FOR QUAIFE INSTALL
Old Feb 25, 2004 | 03:40 PM
Ek00fbp's Avatar
Default TORQUE SPECS FOR QUAIFE INSTALL
Hi, I would like to know the torque specs for the following bolts when installing a new lsd.
The 14mm bolts holding the ring gear to differential?
The 5 10mm bolts holding down the shift forks and gear stacks?
the 12mm bolts holding down the tranny casing?
The big drain bolt at the top of the casing that covers the C-clip?
The 2 bolts on the side of the casing with the spring and ball in them?
If I could get those answered I would really appreciate it.
Old Feb 25, 2004 | 04:11 PM
Ek00fbp's Avatar
Default Re: TORQUE SPECS FOR QUAIFE INSTALL (Ek00fbp)
bump
Old Feb 25, 2004 | 04:23 PM
RedlinedVTEC's Avatar
EDIT: Forgot some values
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">
74.5 lb/ft
11 lb/ft
20 lb/ft torque these in a criss cross pattern.
18 lb/ft and put some rtv sealant on the threads.
Big one by starter:
40 lb/ft
Smaller one near VSS:
16 lb/ft
Also you may need value for reverse idler gear bolt: 33 lb/ft
Old Feb 25, 2004 | 04:24 PM
Ek00fbp's Avatar
Default Re: TORQUE SPECS FOR QUAIFE INSTALL (RedlinedVTEC)
Thank YOu!! This one should be good for the Archives.
Modified by Ek00fbp at 4:07 AM 2/26/2004
Old Feb 25, 2004 | 07:17 PM
Ek00fbp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Big one by starter:
40 lb/ft
16 lb/ft
I was looking and both bolts are the same size one is above the other??
Old Feb 26, 2004 | 10:47 PM
Ek00fbp's Avatar
bump??
D16SohcVtec
Jun 4, 2008 03:52 AM
msinsky14
12
Feb 23, 2007 09:41 AM
dohcgarage@714
Aug 1, 2006 01:09 PM
hybridb18
Jun 13, 2003 09:02 AM
