torque spec on differential bolts?????
Old Jun 13, 2003 | 12:03 AM
hybridb18's Avatar
Default torque spec on differential bolts?????
anyone know how much to torque the bolts on a b16a diff. the stupid left handed threaded bolts, that hold the ring gear on
Old Jun 13, 2003 | 01:47 AM
_BEN_'s Avatar
Default Re: torque spec on differential bolts????? (hybridb18)
I got this from helms gsr manual so the specs should be close enough.
Remember most torque wrenches are not accurate for left handed threads because they are only calibrated in one direction
The book states:
Final driven gear chamfer on inside diameter of final diven gear faces carrier.
Install the final drive gear by tightening the bolts in a crisscross patttern in several steps. 101N-m (10.3 kgf-m, 74.5lbf-f).
Old Jun 13, 2003 | 09:02 AM
hybridb18's Avatar
Default Re: torque spec on differential bolts????? (nosepkr)
thanks, thats good enough for me, i only did them to 50lbs
90teg
Sep 4, 2005 07:59 AM
ViperbitGSR
Apr 3, 2004 12:21 AM
Ek00fbp
Feb 26, 2004 10:47 PM
